Go to Post If the GDC made a game that consisted of driving in a straight line, it would probably be the hardest game in FRC history. - themccannman [more]
Unread 14-03-2012, 19:35
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Who has had a leaky battery this year?
We had two batteries leak this year with no signs of mechanical damage. This was a small amount of acid appearing near the two rectangular indentations near the terminals on top of the battery. We do not think they were over charged, and we were using the standard single battery chargers sold by Andy-Mark.
I hear via rumor that at least a few other teams at our regional had at least one leaky battery this year as well. These were the first two leaky batteries our team ever had, and according to the safety folks I spoke with at regionals battery leaks have been fairly rare in the past few years. Hopefully we are not looking at a systemic problem or a bad lot of batteries, but I am curious to hear from other teams that may have had leaking batteries this year. If you did have a leak, did you notice the location or any other significant conditions?
This is the zeroth day of the rest of your life.
Unread 14-03-2012, 19:46
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Who has had a leaky battery this year?
Which orientation do you charge and use your batteries in (ever upside-down)?
Also have you noticed any bulging in the case or missing the top rectangular cover on either battery?
Also do you notice any movement or play in the terminal lugs on the batteries?
-Michael Dessingue
Unread 14-03-2012, 20:25
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
Our batteries are placed in the robot horizontally, but we did this in 2010 with no issues. This year, two batteries, one that was used in the robot and one that was just sitting on a table, showed up with staining beneath the tape holding on the label.
Unread 14-03-2012, 20:28
T,
Are both batteries from this year? Had you run them in the robot during matches while on the bridge or going over the barrier? Do your students carry them by the wires? All of these can cause seal damage to the batteries.
Unread 14-03-2012, 20:43
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
I believe we cracked the glass on the inside of our batteries by playing with them laying horizontally in 2008 at the San Diego regional. No idea if problems like leakage could be related though. (I've never observed any leakage myself)
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 14-03-2012, 23:26
The "glass" is a fiberglass mat. Perhaps someone who has taken one apart could comment on how brittle it is and likely it would be to crack.
Unread 15-03-2012, 00:52
tsaksa's Avatar
I believe the glass mat is not very brittle, but perhaps I can track more information down without needing to dissemble a battery. By a strange coincidence the battery separator material is actually made in our town.
Unread 15-03-2012, 00:54
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Wikipedia has some decent images of that.
Unread 15-03-2012, 02:31
note: DO NOT OPEN UP YOUR BATTERIES EVER. Thanks for your time
now for the lazy:
Also these look roughly like what we use if i had to guess
Unread 15-03-2012, 12:39
tsaksa's Avatar
An important note. Both batteries were labeled with a large paper label and tape that covered the area marked (pressurized vent system). There was also very little liquid present, and it was only noticeable because there was paper and tape trapping it in the area we now know is a vent. There is at least some possibility that the batteries did not actually leak, but that it was just that the tape trapped and helped to condense normal venting gasses.
I will carefully look over the batteries later this week and see if this may be the case. One interesting fact is that the person responding to the leak commented that baking soda did not fizz when dumped on the battery. This along with the very limited amount of liquid suggests to me there is at least some chance that this is not a classic spill.
Don't worry, I will be careful. I just want to make sure that we know what happened. I suspect that we may at least want to have whoever labels batteries in the future be more careful not to accidentally cover the vent area.
Unread 15-03-2012, 13:07
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
We had two batteries leak in 2011 - new ones from FIRST. We checked the chargers for current, voltage, etc? and was not able to determine the nature of the cause. We had FIRST personnel at the Troy district tournament last year working with us to help figure our the issue to no avail.
Speculation on my part is that the batteries may have been dropped in shipment.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 15-03-2012, 17:35
T,
A normal by-product of the charge and discharge cycle is water vapor due to heat genrated within the cell. The vents open to release this pressure in the form of vapor. Even though the manufacturer says the battery can be charged in any orientation, I recommend that the battery only be charged in the upright position. Any liquid at the vent will be forced out when the cell pressure exceeds the vent trip. That liquid then pushes out of the vent. Following the charge cycle this water then recombines in the cell. As a battery loses water, it's peak capability is also lost. In gel cells this is more of an issue as the gel then decreases to the point were the plates are not fully covered by electrolyte. With gel cells it is/was easy to pickup a battery and actually feel the weight loss compared to a newer battery.
Unread 15-03-2012, 17:41
tsaksa's Avatar
T,
Thanks.
I had a feeling the labeling was a tad excessive and the batteries may not have been really leaking. I will discuss this with the team and make a plan for how to proceed. Batteries remain one area where we need to exercise more diligence.
Unread 15-03-2012, 21:23
DonRotolo's Avatar
Back to humble
FRC #0832
OK Folks, after 25 years in the industry, I think I know a little about batteries, maybe. Search my posts to be sure.
We had a battery start leaking at the negative terminal this year, a 2011 battery. It was charged properly, handled properly, etc. Literally out of nowhere it started to leak.
I'll be cutting that one apart* to analyze that failure later this season. For now it is contained properly. More soon.
* I am a trained professional and have cut (literally) thousands of batteries apart in my career. I have seen people injured badly by flying highly-concentrated sulphuric acid and small chunks of lead while doing this. If there ever was a time to hear and obey this, it is now: Do not try this at home.
Unread 15-03-2012, 23:01
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I just took a close look, in pretty good light, at one of the batteries looking for the vent(s) mentioned above. I'm presuming it/they is somewhere in the black "cap" on top, but I did not recognize anything obviously as a vent. It all looked pretty solid to me. I was wonder what part could be taped over to cause a problem.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
