Go to Post Solutions are more likely to be implemented if you provide the solution along with the concern! - Jessica Boucher [more]
Unread 14-03-2012, 21:23
eet123's Avatar
eet123 eet123 is offline
FRC #0470
eet123 is an unknown quantity at this point
Good Elimination Srategy!
Ok sooooooooooooo, the key strategy to winning elimination is for the first minute and a half (dependent on how long it takes you to get on the bridge) just shoot and score as many goals as you can. Then get your alliance to figure out how to triple balance (suggestion: practice field.) Time after time the alliance that won waterford continually triplpe balanced and beat the other team no matter how many points the other team shot...
Unread 14-03-2012, 21:30
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Good Elimination Srategy!
So you're saying that the way to win is: Shoot balls better than other people, then balance! How shocking.
Xaviermw191's Avatar
Xaviermw191 Xaviermw191 is offline
FRC #0191
Xaviermw191 is on a distinguished road
So let me check this.
We should score alot of balls in hybrid and teleop.
And we should try to get as many robots balanced on the bridge as possible.
Sounds pretty good to me!
Unread 14-03-2012, 21:35
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
The defense is playing wrong if you can pull off a triple balance.
Unread 14-03-2012, 21:36
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
What if you are trying to triple balance from within your own lane? How could that be defended against?
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 14-03-2012, 21:39
Gray Adams's Avatar
If you send one bot to play one on one with one of their bots, you can block them from getting on the bridge or crossing the bump. If you can push, then t-bone them until they run out of time. It's not a pin unless they're touching a field element.
Unread 14-03-2012, 21:41
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
This may be called under as blocking the flow of the game, but an alliance can have one robot sit by the bridge opposite of the lane, and have one robot guarding the center of the field to stop robots from reaching their lane. The key is a danger area for the alliance trying to get in the lane limiting the zone needed to be defended.
I don't know how practical this defense is but it is technically possible.
Unread 14-03-2012, 21:43
Gray Adams's Avatar
It works really well, especially if one of your alliance partners manages to flip and block your lane. I don't know when you cross the line between blocking balancing and good clean defense, but 2068 played that on us really effectively. They could have won the match if they kept it up.
Unread 14-03-2012, 21:44
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
I believe the gdc clarified last year at championships that blocking the flow of the game is when two or more robots work together to prevent robots from getting across though I do not know if that is the case this year.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 15-03-2012, 00:38
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
JakeD will become famous soon enoughJakeD will become famous soon enough
There is a good point to be made here still, figuring out the fastest and best way to triple balance is not as trivial as it looks. You have to be aware of which robots can hang off the ends of the ramp, and which have the power to push the rest of the team up the ramp if needed. Look at Oregon, 3711 was a 4 wheel drive robot with a large wheel base. This means 2 things: 1. they can hang off the end of the bridge, 2. they will high center if they attempt to go last up the bridge and possibly be flipped. In practice what this means is that when you watch the videos you'll notice that in every triple balance 3711 goes up first, the bridge goes all the way over and rests on the opposite side, then 360 crawled up the other side until the bridge fell back to rest balanced. It took multiple practice attempts in the pits before the alliance could pull off a triple balance in every win through eliminations.
Unread 15-03-2012, 07:14
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Another strategy that the winning alliance used at the Rutgers District was to have their best shooter stay in the key and have their second best bot feed them balls, and just have the third bot play defense.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 15-03-2012, 10:10
470-RBTX's Avatar
470-RBTX 470-RBTX is offline
Team Schmooze Captain
FRC #0470 (Alpha Omega Robotics)
470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of
I think what my teammate is trying to say is that the bridges play the biggest role in the qualification matches, but in the elimination rounds it's all about making shots.
470, 3620, and 1025 were the only alliance to prevent the HOT, Las G. and Crev alliance from triple balancing at Waterford, but we still lost because we couldn't put up the number of shots they were while we were playing defense.
When it comes down to it, in the elims, you score as much as you can as fast as you can, balance and just forget about the other alliance. If you're max points weren't enough to beat them then so be it, but playing defense is pointless in elims.
Unread 15-03-2012, 11:26
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Unread 15-03-2012, 12:04
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
I'm not really sure why you think playing defense is pointless in elims...
I'd contest that defense is far from pointless in either elims or quals, but I'll just focus on elims.
I guess part of a disagreement could result from how defense is defined... I'd say it's any actions you take to make scoring harder on the opposite alliance. This year, I think of moving balls from their zone to yours, blocking their path to their scoring location, blocking/reducing their ball supply, preventing them from getting to their bridge, etc.
When winning the match is the dominating motive, the question on whether or not to play defense is "can we inhibit them from scoring more than we could score if we weren't defending them?" - if the answer is "yes," play defense! Given that this year three robots can't all score from the near zone without slowing each other down some (due to space and ball supply constraints), you will usually find that you want at least one of your robots to not be scoring balls from the near zone.
So, what do these other robot(s) do? Well, they can indirectly assist with scoring balls (feed from near/far zone, keep opposing defenders away), they can assist with scoring bridge points, or they can play defense. Given that there isn't a whole lot you can do to aid with balancing for at least the first 60-80 seconds of the match, they should assist with scoring or play defense...
This is where it all starts coming down to the skills of those not scoring balls... Perhaps they're really great at harvesting and passing balls... Quite likely by picking up balls from the far zone and shooting (or ferrying) them over, they could have more of an impact than if they were playing a different type of defense. Alternatively, there may be a robot harassing your top scorer... Your partner may have more of an impact by keeping that defender off than by playing defense on the opposing scorers. There certainly are some robots that are exceptionally good defenders through a combination of strategy, robot capability, and smooth driving.
It usually only occurs on a very deep field that all three of your robots at all points in the match can do more by scoring than by playing defense... and even then it's far from always the case! Really, whether to play defense or not is a case-by-case decision; however, there certainly do exist alliances that may not be benefited by playing defense and alliances that can benefit tremendously from it.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 15-03-2012, 15:41
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
When watching the Chesapeake competition, I saw two types of defence- playing straight defence against teams, pushing them around, attempting to block them from getting to the bridge, etc, etc, was not very effective.
On the other hand, I also saw team 2534 playing defence very effectively. They went over the bump almost immediately and started shooting every ball they could back to the other side. With their long range shooter, they even made a couple shots from that distance. But that ball deprivation strategy allowed them to pull off a couple wins that I would not have expected them to get otherwise. I think that this kind of strategy could be very effective in elims.
Proud 360 Alumni
Volunteer of 6 years
Supporting my good friends on Skunkworks, Mean Machine, and Pandamonium in Spokane and Silicon Valley
