Go to Post How come CD doesn't have a "Like" button??? - dlavery [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 14-03-2012, 22:51
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Extracting Data from FRC-Spy
Hi everyone,
I want to use the xml data from FRC-Spy to automatically update match results on our team website. My issue is I don't know how to extract the xml data from FRC-Spy. I know you should be able to add "xml=2" to the end of the address to get all the match results in xml, but I can't manage to get the actual information off the website. I'm using php with simple xml.
So far this is what I'm having trouble with:
PHP Code:
$allmatches simplexml_load_file("http://www.chiefdelphi.com/forums/frcspy.php?xml=2.xml");
This never actually loads the file so that I can use it. The server is running php 5.2.17.
Any suggestions or example code would be great, since I am pretty new to php.
Also, if I need to clarify anything, let me know.
Unread 15-03-2012, 11:39
KeatonM's Avatar
KeatonM KeatonM is offline
FRC #0027 (Team RUSH)
KeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant futureKeatonM has a brilliant future
Re: Extracting Data from FRC-Spy
The main problem is with your URL. '?xml=2.xml' should just be '?xml=2'.
You can also add '&teams=4096' after the 2 to filter to a specific team.
Here's some sample code and a demo that (I think) provides the information you're looking for.
Demo - I use team 27, since your team has no results in FRC-Spy yet - http://keatonismy.name/dev/frcspy.php
PHP Code:
<?php
//$allmatches = simplexml_load_file("http://www.chiefdelphi.com/forums/frcspy.php?xml=2&teams=4096");
$allmatches simplexml_load_file("http://www.chiefdelphi.com/forums/frcspy.php?xml=2&teams=27");
//print_r($allmatches);
$i 0;
foreach (
$allmatches as $row){
echo
"<b>Event: </b>" $allmatches->match[$i]->event "<br />";
echo
"<b>Match Type: </b>" $allmatches->match[$i]->typ "<br />";
echo
"<b>Match No.: </b>" $allmatches->match[$i]->mch "<br />";
echo
"<b>Red 1: </b>" $allmatches->match[$i]->red1 "  ";
echo
"<b>Red 2: </b>" $allmatches->match[$i]->red2 "  ";
echo
"<b>Red 3: </b>" $allmatches->match[$i]->red3 "  <br />";
echo
"<b>Blue 1: </b>" $allmatches->match[$i]->blue1 "  ";
echo
"<b>Blue 2: </b>" $allmatches->match[$i]->blue2 "  ";
echo
"<b>Blue 3: </b>" $allmatches->match[$i]->blue3 "  <br />";
echo
"<b>Red Score: </b>" $allmatches->match[$i]->rfin "  ";
echo
"<b>Blue Score: </b>" $allmatches->match[$i]->bfin "<br />";
echo
"<br />";
$i++;
If you uncomment the print_r line, you'll see the raw XML for your query.
Also, unless you're set on coding this from scratch yourself, team 862 has a nice system for retrieving match results with simple configuration. Check out http://lightningrobotics.com/Content...agename=lrmrrs and the CD thread http://www.chiefdelphi.com/forums/sh...d.php?t=104249
Team RUSH 27 Alumni
Personal/Resume: http://keatondm.com
Social: http://twitter.com/keatonm27 & http://facebook.com/kdmantz
Anyone who has never made a mistake has never tried anything new.
- ALBERT EINSTEIN
Unread 15-03-2012, 11:46
Dkt01's Avatar
Programming Mentor
AKA: David
FRC #1756 (Argos)
Thank you so much! I figured I made some simple mistake, but that's part of learning.
Unread 15-03-2012, 17:40
Dkt01's Avatar
Programming Mentor
AKA: David
FRC #1756 (Argos)
Actually, after more digging and debugging, my issue was that I can't directly access external websites on this server (something like that). By using curl, my problem was solved. Thanks for the explanation on how to make FRC-spy filter by team, though.
Unread 15-03-2012, 19:44
Just a heads-up: Before you invest too much time in this, you might want to read these posts:
http://www.chiefdelphi.com/forums/sh...5&postcount=58
http://www.chiefdelphi.com/forums/sh...7&postcount=59
