Go to Post this is robotics--everything is going to go wrong at some point, it's how we deal with it that counts - abigailthefox [more]
Unread 12-03-2012, 13:03
Michael_Lee Michael_Lee is offline
FRC #2976
Michael_Lee is an unknown quantity at this point
How to build the SmartDashboard?
SmartDashboard has a bug where you need to press 'Enter' to send a value over to via 'GetString' or something similar -- the Enter key is also the binding to put the robot in Disabled mode.
Team 694 submitted a patch, but as far as I know, it hasn't been applied to the repository and no file releases have been published on firstforge after the patch was submitted -- the patch was submitted in February 12th, but the last file release was updated in January and the repository in February 4th.
I was able to download a copy of the repo and apply the patch, but I'm fairly new to Java -- I have no clue how to build it. I tried installing NetBeans and building the smartdashboard project, but it complained of unresolved references.
Could somebody either give me instructions on how to build smartdashboard or provide a link to a download of the client with the patch applied?
Unread 15-03-2012, 11:07
FRC #2976
Re: How to build the SmartDashboard? [SOLVED]
For future reference, I figured out how to do it. You need to first download the following project from the repo before attempting to build it.
http://firstforge.wpi.edu/svn/repos/...ent/Java/trunk
Unread 15-03-2012, 15:05
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
If you don't want to build anything, then you can use the extension linked to in this post (press the arrow after Sunstroke in the quote box to go to the post):
Originally Posted by Sunstroke View Post
Alright, I've created an extension which will simulate the enter key being pressed on the SmartDashboard when you push a button.
To use it, download the attached .zip, pull the .jar out of it and put it into "\Program Files\SmartDashboard\Extensions", then run the SmartDashboard.
Select "View/Add.../Enter Key" and there will be a button you can use.
Unread 18-03-2012, 00:43
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
I recently built the dashboard with the patch you mentioned. You can find the jar here:
http://www.chiefdelphi.com/forums/sh...d.php?t=101268
No promises, I don't have a robot to test it on, but give it a try and see if it works. If you still want to know how to compile it yourself, I'd be more than happy to help you. Just reply so I know you still care.
