Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 11-02-2012, 16:40
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: 2012 Scouting Form
Originally Posted by EricLeifermann View Post
What you really want to know this year is
How many baskets scored
Any penalties
Did they balance on the bridge
Final score of match
did red or blue win
and a place for comments. Such as they only can only score while touching the fender, etc.
It doesn't matter what basket they score on. I am going to pick the robot that scores the most points. Do i want the robot who scores 100 balls on the low basket or the robot who scores 10 balls on the top basket?
Two things:
We never have had scouts record the result of the match as all the information is available online. I don't think we have ever even looked at the data, anyway.
How are you going to determine which robot scores the most points if you don't know what basket the scored on?
Unread 11-02-2012, 17:00
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
I like the score of the match and who won, especially this year when an 0-8 team can be ranked the same as a 8-0 team. The scores allows you to to see a correlation between each match, yes they are posted online but why look them up after the fact.
Knowing where they score is perfectly fine thing to track, but its not necessary. I say this because if they score 100 baskets in the bottom hoop its 100 points but 10 baskets in the top hoop is only 30. Yes there is a curve where the 1 or 2 pointers are worth less than the same amount of 3 pointers but if you know a team can score 10+ baskets who cares what hoop its in. Yes I understand that most teams aren't going to be able to score 10+ points so know where they do score is good. So there isn't a reason why you wouldn't track what basket they score in, im just saying its not the most important thing.
2012-2016 Wave Robotics Team 2826
Unread 11-02-2012, 19:15
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Attached is latest version working on Windows 7. We're still working on cleaning it up. 3rd attachment shows the input form. I hope no one here is on team 306... No offense intended, it's just bogus data.
Originally Posted by ChristopherSD View Post
Please tell me this comes on Windows.
Yes. It doesn't use any platform-specific calls.
Why do you need to know where they take each shot? You want your scouters to be able to collect data fast and accurately. Having your scouters looking up and down from the field to the paper will decrease both. The less the scouters need to focus on the better the data you are going to get.
Any penalties
did red or blue win
See, we have 6+ people watching each game and it will be fairly easy for them to record the baskets scored with our scouting program. It's not like they're going to be doing anything more important anyway.
Also, if you just calculated points, you would have to make the scouts do "*3" and "*2" or "*3+3" for baskets scored in upper baskets or in autonomous. Much easier if they can just click a button.
ID:	11859  Click image for larger version
ID:	11860  Click image for larger version
Unread 11-02-2012, 22:26
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Originally Posted by Siri View Post
Yes and no--fouls will be signaled to the crowd, but not discussed/announced afterwards. And of course the score will change, but only after the signal is given. You'll definitely know if you're looking, but I am a little worried about my scouts catching them while watching the robot. This is challenge enough as a coach, and I've met may coaches who miss such things.
Also, you'll only be "told" which rule the foul is on for the "most common" fouls. Our at least our best guess at the most common fouls. The rest will take some deduction on the part of the scouts. Something to consider depending on the experience/knowledge/attentiveness of your scouts.
Yes, you're right. I wasn't clear. I think the best practice would be to instruct scouts on recognising fouls themselves, but if that fails, they should be able to watch the referees, since this year's scoring isn't very difficult with only 3 balls per robot (at a time) and a relatively slow endgame.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 11-02-2012, 23:19
XaulZan11's Avatar
FRC #1732
In your example how do you know they scored 100 baskets in the bottom hoop or in the top hoop or some combination if your scouts don't record it?
Unread 12-02-2012, 21:55
wilsonmagnet's Avatar
wilsonmagnet wilsonmagnet is offline
FRC #0191
wilsonmagnet is an unknown quantity at this point
Next revision. Feedback still welcome.
Paul Daniels | FIRST Team 191 | X-Cats
Joseph C. Wilson Magnet High School
Rochester Engineering Centre, 30 Hart St
Unread 14-02-2012, 19:45
FRC #0191
Revised version of 2012 Scouting Form with support documents:
ScoutReport - to report alliance and opponent data for upcoming matches
ScoutSummary - to summarize individual team data for alliance selection
Unread 03-03-2012, 22:42
FRC #0191
Attached are the Scouting Forms we will use next week at the Finger Lakes Regional. Go X-Cats!
Unread 15-03-2012, 16:18
G-HousePirate's Avatar
G-HousePirate G-HousePirate is offline
PirateCesar354
AKA: Cesar
FRC #0354 (Westinghouse Pirates)
Team Role: Student
G-HousePirate is an unknown quantity at this point
Team 354 has come up with a general scouting sheets as an printable on and an excel one.
First Team 354 Westinghouse Pirates
Unread 15-03-2012, 18:47
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Have any of you practiced using your scouting ideas/sheets/systems while watching one or more of the re-cap videos of a match? I know that some videos are not well-suited for scoring practice because the cameraman has taken an interest in some particular action to the exclusion of field coverage.
I would think that if several of your scouts come up with close or identical results on your system, then you will know that you have a degree of consistency and utility in the data they are generating. If there are wide differences in how your scouts react to the same match, then you need to find out why that is. Either it's a form deficiency or your scouts are literally not on the same page in their understanding of what is required of them.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
[IMG] code is Off
