Go to Post However, the skill of calculating things by hand and sketching by hand is something that we should continue to teach the youth (until my netbook can run Inventor :D) - Zach O [more]
Unread 15-03-2012, 18:41
ENeyman's Avatar
ENeyman ENeyman is offline
AKA: Emmett Neyman
FRC #3929 (Atomic Dragons)
ENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant future
FRC Bridge Weight
Does anyone know the weight of the FRC bridge? Or how much force is needed to tip it.
Unread 15-03-2012, 18:48
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: FRC Bridge Weight
22 lbs at the end is the number I've heard being thrown around. You should design with considerably more than that if you want to be able to push anywhere but the very end (really hard to hit it there), and do it quickly.
Unread 15-03-2012, 20:35
Suitster's Avatar
Suitster Suitster is offline
AKA: Ethan Pellittiere
FRC #3951 (SUITS)
Suitster is on a distinguished road
Get your arm up to the level where you worry about things breaking
we had a 14" am powered by two window motors that wasn't strong enough for competition
we ended up adding weight to the arm (a package of electrical tape) and we still could use more
Something we figured out works for the bridge at FLR was if you rock the bridge and keep hitting it when it is moving down, you can knock the bridge over fairly quickly
Unread 15-03-2012, 20:42
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Are you sure that it is 22lbs? I thought that it was supposed to be around ~16lbs.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 15-03-2012, 22:06
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
This.
On another note, please use the search function to find this information in the future, rather than starting new threads.
Originally Posted by slijin View Post
The video said 28" to 30", so assuming 29" is the tipping point, 26" is the effective tipping point (CoG of battery isn't at the end). Keeping in mind that the bridge rotates on the edges of the bump and not the exact center, subtract another two more inches to get 24". Two batteries are 27 lb. That gives 27 lbf * 24" * (1'/12") = 54 lbf-ft = 648 lbf-in.
However, because of the double hinge, it's not a perfect lever, so aim for a bit more than that.
(88"/2) - 2" = 42"; 648 lbf-in / 42 in = 15.4 lbf, so approx. 16 lbf to tip.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 18-03-2012, 10:31
EFastring EFastring is offline
AKA: Eric Fastring
FRC #2078 (Robotic Wolves)
EFastring is an unknown quantity at this point
After hearing the 16lb number, we designed an arm that could push down on our bathroom scale ~20 lbs (Banebots RS550, 64:1 transmission, ~15" length). At competition on practice day, we couldn't lower the bridge. We thought about adding weight to the end of the arm, but decided to swap to a locking wedge design instead.
A window motor at that arm length puts out about 4-5 lbs.
