Go to Post Success is realizing that anything is possible, persistence is the key. - SlamminSammy [more]
Unread 15-03-2012, 20:42
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Re: FRC Bridge Weight
Originally Posted by Grim Tuesday View Post
22 lbs at the end is the number I've heard being thrown around. You should design with considerably more than that if you want to be able to push anywhere but the very end (really hard to hit it there), and do it quickly.
Are you sure that it is 22lbs? I thought that it was supposed to be around ~16lbs.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 15-03-2012, 22:06
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
This.
On another note, please use the search function to find this information in the future, rather than starting new threads.
Originally Posted by slijin View Post
The video said 28" to 30", so assuming 29" is the tipping point, 26" is the effective tipping point (CoG of battery isn't at the end). Keeping in mind that the bridge rotates on the edges of the bump and not the exact center, subtract another two more inches to get 24". Two batteries are 27 lb. That gives 27 lbf * 24" * (1'/12") = 54 lbf-ft = 648 lbf-in.
However, because of the double hinge, it's not a perfect lever, so aim for a bit more than that.
(88"/2) - 2" = 42"; 648 lbf-in / 42 in = 15.4 lbf, so approx. 16 lbf to tip.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 18-03-2012, 10:31
EFastring EFastring is offline
AKA: Eric Fastring
FRC #2078 (Robotic Wolves)
EFastring is an unknown quantity at this point
After hearing the 16lb number, we designed an arm that could push down on our bathroom scale ~20 lbs (Banebots RS550, 64:1 transmission, ~15" length). At competition on practice day, we couldn't lower the bridge. We thought about adding weight to the end of the arm, but decided to swap to a locking wedge design instead.
A window motor at that arm length puts out about 4-5 lbs.
