Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 16-03-2012, 00:29
Robobuff1.0's Avatar
Robobuff1.0 Robobuff1.0 is offline
FRC #1633
Robobuff1.0 is an unknown quantity at this point
Smile PID Auto Aim Question
okay I did plenty of research here on chiefdelphi and the NI example codes. Now what I am trying to do is to use the camera and center our robot using a turret. I am a rookie programmer and dont really know much about PID and vision processing. My question is if the attached code below is right and how do I choose for it to track the top or middle hope? It will be very helpful if I see an example. (and I haven't put the refnum yet so don't worry about that part.) Thanks in advance our team will appreciateit
Name:	PID control.png
FRC: 1633
FTC: 2873
Unread 16-03-2012, 09:28
Re: PID Auto Aim Question
Originally Posted by Robobuff1.0 View Post
okay I did plenty of research here on chiefdelphi and the NI example codes. Now what I am trying to do is to use the camera and center our robot using a turret. I am a rookie programmer and dont really know much about PID and vision processing. My question is if the attached code below is right and how do I choose for it to track the top or middle hope? It will be very helpful if I see an example. (and I haven't put the refnum yet so don't worry about that part.) Thanks in advance our team will appreciate it
I see only one input going into each PID. Each PID needs both a setpoint and a process variable input.
Unread 16-03-2012, 11:13
FRC #1633
That was kind of part of my question I have never used PID before so I dont really know what to put, what are those (setpoint and process variable input) and what do I put for those?
FRC: 1633
FTC: 2873
Unread 16-03-2012, 11:30
Read the LabVIEW help for PID. It explains a lot.
Then look at this example:
http://team358.org/files/programming...PIDexample.jpg
Then read this explanation:
http://uberbots.org/o/Resources/For_...ms/PID_Control
Then search CD for PID threads.
Then ask specific questions about what you don't understand.
Unread 16-03-2012, 12:52
FRC #1633
Thank you! that was very helpful I understand it better now
FRC: 1633
FTC: 2873
