Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 15-03-2012, 20:05
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
GetLocation() or GetAlliance()
Hello,
I am wondering how to use either of the two functions (GetLocation() or GetAlliance()) whic gets the location or alliance off of the Driver Station.
I want to make it so that I can have 2 or more different autonomous'. How would I fully implement this?
Thanks,
Davis
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 16-03-2012, 10:16
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: GetLocation() or GetAlliance()
You can actually read the joysticks during disabled. I setup a snippet of code this week to read the driver joystick and check if the trigger is held for 3 seconds, and switch to a different autonomous routine.
For reference, here's that chunk out of my code
static Timer button_combo_timer;
if (BUTTON_COMBO_SWITCH_AUTONOMOUS() == true)
    button_combo_timer.Start();
else
    button_combo_timer.Reset();
    button_combo_timer.Stop();
if (button_combo_timer.Get() > 3.00)
    switch (autonomousMode)
    case AUTONOMOUS_MODE_1:
        autonomousMode = AUTONOMOUS_MODE_2;
    break;
    case AUTONOMOUS_MODE_2:
        autonomousMode = AUTONOMOUS_MODE_3;
    break;
    case AUTONOMOUS_MODE_3:
        autonomousMode = AUTONOMOUS_MODE_1;
    break;
    default:
    driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 1");
    break;
    driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 2");
    break;
    driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 3");
    break;
driverStationLCD->UpdateLCD();
Unread 16-03-2012, 20:28
FRC #0539 (Titans)
Interesting, where would I place that to read it before a match?
Thanks
FRC Team 539
Unread 22-03-2012, 11:39
Programming Mentor
AKA: Joe S
If your using iterative robot, in
void DisabledPeriodic(void){
I'm not sure if your using simple robot though
