Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 17-03-2012, 09:27
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Labview on PC using udp C++ on cRIO need udp server solution
My team has labview getting correct distances on the DS. We just can't get them to the driver station. Desperately needing help.
Unread 17-03-2012, 09:32
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Labview on PC using udp C++ on cRIO need udp server solution
Do you mean you are having trouble sending data from the cRIO to the Dashboard? If so, you'd flatten your data to a string and send it via Set User Data High.vi.
Unread 17-03-2012, 09:35
No I need to receive the data on the robot. I do not have a viable solution at the moment. How would I schedule a udp server that runs threaded on the robot. I am out of my depth on that. Networktables I can not get to work.
Unread 17-03-2012, 09:54
There are other threads on this with more deails, but generally, I'd suggest using UDP. An example of this is in the dashboard already, where the Kinect info is read from the DS. Change the read to a write, and change the port and the LV side should be done. I don't know that I can point you to a UDP example for C++, but I suspect you can google and find some.
Greg McKaskle
Unread 17-03-2012, 10:44
I have found some. I just wanted to know how to fork off a process so that it was running in background after starting robot.
Unread 17-03-2012, 10:59
I think WPILib includes a task class that will wrap the posix thread APIs. That should make it pretty easy to do.
Greg McKaskle
Unread 17-03-2012, 11:54
Thanks I will try that. Write now we are messing with your networkable you made in LV. Will the robot c++ code work with that combo? Are they combatable is basically what I am asking. Will find out in the next 30 minutes.
Next year all Lab view this is not fun trying to glue all these dissimilar things together.
Unread 17-03-2012, 13:12
Hopefully the LV and C++ network tables are compatable. I've tried Java and LV in simple cases and I put it into beta to see what worked. Please let me know.
Greg McKaskle
