Go to Post Those teams with too much pride will hinder their alliance. Know your strengths and weaknesses and be honest about them. - Andy Brockway [more]
Unread 17-03-2012, 13:20
random_hero random_hero is offline
FRC #3297
random_hero is an unknown quantity at this point
How do you wire the DC/DC converter?
We are working with our extra robot for something to do in our down time. We have blown 2 D-Link bridges when powering on our robot.
We are going from the 12V port on the power distribution blue thing, to the dc/dc converter, then from the dc/dc converter to the bridge. As the negative cable on the d-link cable that we cut, we are using the wire with the dashes on it, which i assume was the negative cable. What are we doing wrong? Thanks.
Unread 17-03-2012, 13:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How do you wire the DC/DC converter?
Probably what you are doing wrong is assuming that the dashes means negative.
Look at the label on the bridge, does it have a little drawing of the power connection and + and - labels?
Unread 17-03-2012, 13:31
Random,
Regardless of whether you think you have done the correct wiring, prudence demands that you get a meter and check that the polarity and voltage at the connector matches the bridge before you plug it in. It is very easy to use a meter to check continuity to the inner and outer terminals of the plug.
Unread 17-03-2012, 13:41
This is from page 30 of Getting Started with the 2012 FRC Control System.
As you can see, the center pin (green arrow) is positive and the shield (red arrow) is negative. Use a cheap ohmmeter to figure out which wire is negative.
Unread 17-03-2012, 17:31
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
My experience has been that the wire with the dashes is center-pin/positive. TEST FIRST! Your mileage may vary.
