Go to Post Archimedes brings all the bots to the yard! - looneylin [more]
Unread 03-17-2012, 07:02 PM
Re: Tachometer Interrupt Help
Originally Posted by twiggzee View Post
that was it. tried it again, turns out that the getPeriod method only consistently gives a reading when our wheel is spinning more than 1200 rpm. anything below that we get either an "infinity" reading or an occasional reading when approaching 1200 rpm. thanks!
Maybe Java has a "SetMaxPeriod" like C++ does:
* Set the maximum period where the device is still considered "moving".
* Sets the maximum period where the device is considered moving. This value is used to determine
* the "stopped" state of the counter using the GetStopped method.
* @param maxPeriod The maximum period where the counted device is considered moving in
* seconds.
void Counter::SetMaxPeriod(double maxPeriod)
