Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Unread 02-02-2012, 22:39
MKLIM's Avatar
MKLIM MKLIM is offline
MKLIM is an unknown quantity at this point
Camera Problems: not connecting to the CRIO
so i am a first year programmer for my time and only basicly understand labview.
the problem is that when we try and run the "Rectanglular Target Proccessing on the CRIO, i cant find the camera so no image appears
BUT when we run it on the computer and connect the camera directly to the PC we get an image and the targeting tracker works
PLEASE HELP
team 2761
Unread 02-02-2012, 22:44
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Camera Problems: not connecting to the CRIO
Have you run the Axis Camera Setup Tool? If not, this should be the first thing to do. If you have, make sure you are using a crossover cable to connect the camera to the router, or it will not work right.
I'm right 90% of the time, so why worry about the other 3%?
Unread 02-02-2012, 22:45
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
How exactly are you connecting your camera to the cRIO? Are you using the second ethernet port (if you're using the 8-slot) or are you connecting it through the radio?
If you're connecting it via the radio, then the IP address for the camera will have to be changed in the code (I think it's 10.xx.yy.11, where xx.yy is your team number)
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 02-02-2012, 23:13
MKLIM's Avatar
we are running the camera through the dlink port 2
is it a problem of me needing to put the rectanglular processing program into the main vision.vi?
Unread 02-02-2012, 23:15
MKLIM's Avatar
Talking Re: Camera Problems: not connecting to the CRIO
we ran the setup and changed its ip to 10.27.xx.11
and which ethernet cable is the crossover? (we have so many of them)
Unread 02-02-2012, 23:20
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Crossover cable is not required when connected through the dlink
Unread 02-02-2012, 23:35
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Crossover is meant to connect two computers directly such as the camera and the cRIO. IIRC most modern PCs now can connect fine with a standard ethernet thus limiting the crossover cable's use.
Unread 02-02-2012, 23:39
gizmo720 gizmo720 is offline
FRC #1719
gizmo720 is an unknown quantity at this point
I found on my robot that the auto-configuration did not work for the camera. To fix this, I enabled anonymous viewing in the camera's web interface. Also, looking through the source code seems to suggest that a camera connected directly to the crio should have a 192.168.0.90 address, instead of the 10.xx.yy.11 address.
MKLIM's Avatar
alright so it doesn't matter what cable i use
BUT back to the original problem, How do i get the Crio to run the rectangular target processor .vi
Unread 03-02-2012, 08:38
One of the built-in LabVIEW tutorials shows you the steps for adding vision processing into a robot project.
Unread 03-02-2012, 10:19
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
If you just want to see how the Rectangular Target Processing sample runs, open the project in Labview and click the Run button.
You enter the camera's IP address in the sample program's Front Panel when it's running. You will need network access to the camera (if your computer and camera are both plugged into the DLink you are good).
You can then explore the example. Try clicking on the Color or Intensity tab and then click the reflective tape on the image of your target. It is pretty cool how easy this works.
Try lighting the reflective tape by holding a light source right by the camera. This greatly helps to find the target. If you are locating by color, colored LED lights also help tons. We ordered these from SuperBrightLEDs
1 | AEx-x: LED Angel Eye Headlight Accent Lights| $ 5.95 |
AE60-R15: 60mm Diameter Red
good luck!
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 05-03-2012, 23:18
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
I did everything everyone said and I still cant get the image to show up when running it on the crio in step 2 or 3 of the tutorial.
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 17-03-2012, 20:39
arthurlockman's Avatar
arthurlockman arthurlockman is offline
Team Captain
FRC #0172 (Northern Force)
arthurlockman is an unknown quantity at this point
Send a message via AIM to arthurlockman
I think the easiest way to fix your problem is to set your camera IP address, then rather than trying to use the auto-IP detection in the code, just feed it the static IP of the camera. We found that the code doesn't like finding the camera by itself.
Arthur Lockman
Twitter: @arthurlockman
a.rthr.me
