Go to Post The thing about working hard, is you can always work harder. The thing about being great is you can always be greater. - JVN [more]
Unread 17-03-2012, 21:14
Ryan Reliford Ryan Reliford is offline
FRC #1038
Ryan Reliford is an unknown quantity at this point
power distribution board red light stays on
We're getting a red light on one of the 30 amp outputs of the PDB when there's nothing connected to it. We believe it is the cause of an issue we're seeing when we increase the speed of our shooter wheel. Whether this is the cause or not, at higher speeds, everything cuts off and the driver station indicates a communication loss but it's very brief and then we're able to start back up. Several watchdog errors pop up, system and user.
We tried to add a breaker to that port even though it's not being used and noticed that while pushing down on the board itself, the red light for that port goes off. However, it is difficult to tell whether anything improved b/c it's difficult to keep pressing down on the sweet spot that keeps the light off thus causing the same problem of everything cutting out and then back on.
If anyone can shed some light on what we might be experiencing, it'd be greatly appreciated. Thanks.
Unread 17-03-2012, 21:43
Re: power distribution board red light stays on
The red light is supposed to indicate that there is an electrical load connected to the PDB output and the circuit breaker for that output is open (or missing).
If there is nothing connected to that position's red Wago connector but its red light is on, there is something wrong with your Power Distribution Board.
A brief loss of communication is very suspicious. How brief is it? Less than a second, a second or two, fifteen seconds, or what?
Unread 17-03-2012, 21:46
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Furthermore, if a breaker is only solving it when you press down on it, your power distribution board is likely broken (broken trace? bad solder joint?). The connection between the PDB and the breaker is very tight.
Unread 17-03-2012, 21:52
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Before I answer the question, I suggest contacting EricVanWyk, who helped design the PDB and is far more knowledgeable about troubleshooting it than anyone else here on CD. That being said:
Just to make sure there's no confusion at all, this means the light turns on when there is no fuse present and there are no wires connected, correct?
This sounds like a power issue with the DLink; have you made sure that the barrel provides a secure connection and that the converter is hooked up to the dedicated output?
To reiterate Alan's question, how long does it take to reestablish communications? You may also want to observe the DLink lights when you ramp up shooter speed and see if they turn off; if they do, then you know you're having issues somewhere in the power connection.
The new DS allows you to graph the voltage over time; have you tried identifying a voltage threshold at which your communications cut out? Seeing as how the dedicated input is designed to function down to a 4.5V battery, I doubt the PDB itself is your issue, because it takes a massive load to cause a voltage drop that big.
Could you clarify what happens when you do what? i.e.
- Does adding a fuse, 20A or 30A, rectify the problem?
- Do you push down onto the fuse itself, or somewhere else near the suspect slot?
IMO, there are metal shavings and/or a bad connection in your PDB, which would explain the errant light and intermittent connection.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 17-03-2012, 22:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The PD board is a little confusing the first time you look at it. The little lighting arrow points to the circuit the CB is protecting putting the CB on the opposite side. So make sure you really have a CB in the correct slot.
[edit]Read you post a little closer. Sounds more like a bad trace on the board.[/edit]
Unread 18-03-2012, 00:53
FRC #1038
Thanks for the responses. Let me answer some of the questions asked...
How long does the power cut out? The power will completely cut out and the driver station will disable itself requiring us to re-enable to continue.
SLIJN, yes, this is all occurring while there are no wires connected to the output and while there is no cb connected on that particular port. We're not using the DLINK...we're connecting directly from the laptop to the cRIO with an Ethernet cable. I will check the voltage logs.
Does adding a fuse, 20A or 30A, rectify the problem? Do you push down onto the fuse itself, or somewhere else near the suspect slot? We started by trying to push the fuse all the way down and noticed that the light would flicker on and off. We then try to seat it just right so that the light would go off but it would only ever go off temporarily (no more than 20 seconds or so). Pressing on the PDB near where the fuse is also causes the light to go out but it's so touchy that it comes back on if you're not pressing in the "sweet spot".
The brief loss of communication was seen when we pressed down on the board, trying to keep the light off, and we witnessed what appeared to be a breaker tripping (the power cutting out). But, instead of the driver station disabling completely, the power would cut out but then come back on immediately (within a second or two). Again, this scenario only happened while we were actively trying to keep the light off by pressing on the board. Otherwise, the driver station would completely disable itself. So when I say it lost communication, what I'm really trying to convey is the fact that the driver station indicators all go to red, the robot communication indicator included.
Unread 18-03-2012, 02:05
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
sounds to me like you have a short in your PD board(metal shaving, wire strand, etc. got in there) and it's causing brownouts... how long do the lights on your driver station go out for? 2 seconds? 10? 30? more?
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 18-03-2012, 06:31
Slijin - I appreciate the props, but it is always better to post to the board than to PM one specific person. I may have designed the hardware, but I'd argue that e.g. Alan is more experienced with the system than I am.
The blown breaker detection circuits are very small, simple and isolated from the rest of the circuitry. They don't share any circuitry with the radio power supply. I am leaning towards physical damage to your PD. Did you drop or bend it? I saw one team using it as a springy back stop to catch their arm as it dropped last year.
Unread 18-03-2012, 08:31
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Here's the PDB schematic, so you can see how the circuit works. http://www.usfirst.org/uploadedFiles...matic%20v4.pdf
Unread 18-03-2012, 09:02
I am going to agree with Erik here. The LED comes on to indicate that a current path exists but that the breaker is open. Inserting a breaker and pushing it down to extinguish the LED sounds like you are forcing the board below the case or you are pushing down the board until the circuit path opens. I am betting you will find metal shavings on the board or underneath. Using a bright light, look into the WAGO connector and see if you see any crud in either of the ports before opening the PD.
Unread 18-03-2012, 16:23
FRC #1038
Again, there are two ways...First, if we're actively trying to keep the red light off on that port by pressing down on the pdb or by inserting a breaker, the driver station will disable itself and come back on within a second or two. If we're not touching the board and there's no breaker present, then the driver station will disable itself and stay off until we re-enable.
It sounds like we should also check for metal shavings or other debris in the pdb. Thanks for the comments. I'm hoping that's what was causing the driver station to cut out and not something else. Thanks again!
Unread 18-03-2012, 17:59
Ryan,
Since the power supplies are at the opposite end of the PD from the power input, it is possible that conductive material is shorting out the board but I would expect to see some smoke with that kind of current. It really sounds like you have a broken (cracked) circuit board. It is pretty easy to open the case and check inside for foreign debris. Is this a brand new 2012 PD? If it is you may not want to open it without checking on warranty repair or replacement.
Unread 18-03-2012, 21:15
FRC #1038
We can run the shooter wheel fine until we get up to about 5000 rpm. That's when we notice it starting to give out; we can hear the motor whirring up and down a bit and then it cuts out. I'm not sure if it is a new pdb or old but we're going see if there's debris in the port at all. I'm not sure how long this has been going on with this pdb and no one seems to know what might have happened to it.
Unread 19-03-2012, 17:24
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
I pulled our board apart and this is what I found. On CB1 the trace that goes from Q5 to R9 was broken away from the board and folded over. I do not know how this could have happened unless it happened as a factory defect. This board was purchased fall of 2010 and installed as a retrofit to our 2007 machine as a fall training project. This board has never seen competition play and has been sitting dormant since Fall of 2010. I'm thinking this trace was already broken and since it was part of a retrofit of a machine that never really saw much action once the retrofit was complete, we never saw this problem.
My confusion lies in that if this circuit is isolated why would it affect the rest of board when we saw high current draw on another breaker.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 20-03-2012, 07:53
Jimmy,
That is not merely folded over. The transistor (or what remains) of Q5 blew away from the board taking the stripe with it. What is more interesting is that none of the other transistors are in place. During the initial rollout, there was some reason that the 'breaker open' tally circuitry wasn't included. Erik Van Wyk likely remembers why but I don't. There is a lot of debris on the board that may have led to this failure. Please note the solder splash on the lower right of the transistor pad. I am going to bet this is also a contributing factor to the original problem.
