Go to Post Where's my hammer? I need a bigger hammer. - JaneYoung [more]
Unread 16-03-2012, 00:24
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Who has had a leaky battery this year?
Originally Posted by Bill_B View Post
I just took a close look, in pretty good light, at one of the batteries looking for the vent(s) mentioned above. I'm presuming it/they is somewhere in the black "cap" on top, but I did not recognize anything obviously as a vent. It all looked pretty solid to me. I was wonder what part could be taped over to cause a problem.
On the top of the batteries there is a small plastic strip that hides the vents, as show by a bad battery.
Vents
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 16-03-2012, 07:48
Bill,
I don't think that label caused the problem, it simply was the evidence of the vent.
Unread 16-03-2012, 11:28
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Bill,
Agreed. Unfortunately we will never know for sure. Another mentor immediately disposed of the two questionable batteries at a recycle center and they are now gone. I now think there was may have been nothing wrong with them, but it a minor loss to insure safety.
Hopefully this will encourage us to review our battery practices and safety procedures. It appears that not everyone on the team that was handling batteries had the same knowledge or followed the same process. If nothing else we can use this experience to help the students learn more about proper battery safety, care, and at least where we keep the battery spill kit.
This is the zeroth day of the rest of your life.
Unread 16-03-2012, 11:52
Even with training, team members sometimes forget. Here is a short list of battery do's and don'ts.
1. Never lift the battery by the wires. Guaranteed to break the terminal inside the battery.
2. Always use two hands, the batteries are heavy and have no good grasping points.
3. Don't charge when hot, i.e. right after a match. Wait at least 15 minutes.
4. If you run you battery down in just one match, reevaluate your mechanical design. A good rule of thumb is several minutes or at least two matches. Best tested during practice at your build space.
5. Insulate all exposed metal/wire/terminals. The battery is capable of currents that can weld.
6. Insist that only those students or adults that know how the battery is designed to be mounted in the robot actually place the battery in the robot.
7. Do not use the alligator clips on your battery charger to connect to the Anderson Power Products connector. The clips will scratch and deform the contacts which lead to high resistance and high heat. Yes Virginia, high enough to melt/fuse the connectors. There is no good way to insulate the clips for this operation.
8. Do not drop the battery. More batteries have been killed by dropping on a corner or breaking loose internal parts.
9. Test your batteries at least once or twice a season with a good battery checker. West Mountain Radio CBA II or III is a good way to tell battery status without trying to draw huge currents. The Cross the Road Battery Beak, battery checker is also a quick way to check battery health prior to a match.
10. Do not depend on a DMM/DVM to give you any usable data. It will simply tell you terminal voltage without telling you if the battery can actually supply current.
For this year, please insure that your battery will not bounce around inside your robot and many teams, (WildStang included) are adding some padding to prevent serious G-shocks to the case and internals.
Unread 16-03-2012, 12:01
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
And don't take this to mean "If you have big enough hands you can use one". I've almost/slightly pulled something in my thumb multiple times carrying batteries 1-handed using the little ledges on the top
Unread 18-03-2012, 11:02
perlgerl perlgerl is offline
Michelle
FRC #0781 (Kinetic Knights)
perlgerl is just really niceperlgerl is just really niceperlgerl is just really niceperlgerl is just really nice
If the leak was from the terminal seals, this is a manufacturing defect and should be communicated to the manufacturer. Please post the manufacturer (ie Genesis or MK battery) and the manufacturing date code (ie YYMMDD + extra letters) which is stamped in the top of the battery case.
This year in our kit of parts, the Kinetic Knights Team 781, received a Genesis battery manufactured July 17 2010 (batch code E100717FB). We have not had any leaks. We inspected our terminal seals and saw no defects. Some pictures of a disassembled MK Battery are posted on our website (3 MB pdf).
Unread 18-03-2012, 11:17
Diesel Torch's Avatar
Diesel Torch Diesel Torch is offline
Driver
FRC #3548 (Battering Rams)
Team Role: Driver
Diesel Torch is an unknown quantity at this point
Last year we lost 7 batteries because of leakage... This year we upgraded to new chargers and we haven't lost a single one...
Unread 18-03-2012, 11:59
tsaksa's Avatar
Did you switch to a completely different type of charger? If so, what were the old ones, and what did you switch to.
Also, Al Skierkiewicz I really like your list of battery rules. In particular
#6 Insist that only those students or adults that know how the battery is designed to be mounted in the robot actually place the battery in the robot.
I would consider extending this a bit and think our team perhaps should have a formal battery handling certification. I too often here a coach, driver, programmer, or mentor yell, "Anyone!, we need a fresh battery now." Somehow replacing a battery has become some time critical priority, and anyone is considered qualified to replace one. We are trying to get away from that, and insure that proper battery handling procedures are followed. But we seem to be fighting a lot of inertia.
Unread 18-03-2012, 12:24
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Our batteries have a harness made from old seatbelts. When you have installed the cables the battery cannot come out and you have a two inch wide cloth carrying handle. It makes also very easy to remove from the robot. You do have to design the battery box larger to fit the harness. A fellow ham in my ARES/RACES group made the harness originally so 60+ year operators could carry the same size batteries safety
Unread 18-03-2012, 20:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by DonRotolo View Post
I'll be cutting that one apart* to analyze that failure later this season.
I would love to know how that's done (properly).
Unread 18-03-2012, 20:31
Arm-length rubber gloves through a Lexan panel into a ventilated hood?
Unread 18-03-2012, 20:37
Driver
Team Role: Driver
The old ones were the HPX-60's.
The new ones I'm not sure about, but they are similar to the 3-way one on andymark.com but it only chargers one.
Unread 18-03-2012, 21:53
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
With a ROBOT!
Unread 19-03-2012, 02:03
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
2168 received a leaky battery this year.
http://team2168.org
Unread 19-03-2012, 07:53
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
while our battery never leaked (we stopped using it), our battery had come with 1 of the lead terminals weak to the point where i could move it back and forth. That was this year.
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
