Thread Tools |
Rating:
Display Modes |
Alternative to PID speed control
Does anyone know of any way to control shooter wheel speed other than using PID? We are currently using PID and we are getting an oscillating error of about 5%. Any ideas how to minimize this error. (we are currently only using P. And D at all starts an oscillation.)
Re: Alternative to PID speed control
http://www.chiefdelphi.com/forum/sho...21#post1114721 Last edited by Ether : 18-03-2012 at 12:03. |
An oscillation can be changed by changing your P factor. I would think that reducing the multiplier will help, but not knowing your mechanical setup this is just a guess. Experiment by cutting it in half and doubling it, that should tell you which direction to go.
You can write an equation that uses the same set motor speed voltage at a set distance using the same amount of voltage no matter how charged your battery is. See if this helps:
http://www.chiefdelphi.com/forums/sh...9&postcount=17 |
This is untested, but we decided to use the PID VI coupled with a feed forward term to control output velocity.
1. I have heard a lot about a "feedforward loop". Is that just an accumulator? A feedback loop? A picture is worth a thousand words
2. How does the sampling rate affect this. I am currently running the loop at 50ms using a Timed Loop. Does anyone know if adjusting this up or down would help at all? 3. Is a 5% error significant or is the inconsistency more likely rooted in a mechanical problem? |
#8
A feedforward term in a control loop is a term that adds to the control output based directly off of the command input or some feature thereof. It doesn't depend on any feedback, it purely feeds the command signal forward through the control loop.
For instance, in the case of controlling a shooter wheel, there's a theoretical minimum voltage necessary to run the wheel at the correct speed. Based off this, you could create a feedforward term in your control loop. Take a CIM with no reduction. 12V free speed is 5400RPM. So, if you want to run it at 2700RPM, you know you need atleast 6V output. You create a feed forward term with a gain of (12V/5400RPM). Then, your output is PID output + RPMs * (12V/5400RPM). That way, when you command 2700 RPM, you're already outputting the necessary 6V to run at that speed. Your PID loop now only has to compensate for the difference between free speed and your loaded speed. Plus, you're instantly outputting 6V without waiting for an I term to build up enough error to put out 6V for you. Basically, feedforward terms improve the response of your control loop based off features you already know about your system. |
#10
warning: If PID output is +/-1 this may not work as expected.
#11
We used a very simple closed loop control that worked flawlessly. We had a jag on CAN bus with an encoder attached to the jag. We used voltage control with a voltage ramp of ~115 V/S. We queried the jag for speed, and if the speed was less than the set speed, we set max voltage. If the speed was greater than or equal to set speed, we set zero voltage. The inertia of the system kept the shooter speed within ~15 RPM of set speed at all times, and when we shot, the voltage immediately went to full for rapid spin-up.
the simplest solution that works is usually best. |
#12
Thanks for posting that. PS - I assume you had the Jag jumper set for coast? Last edited by Ether : 19-03-2012 at 20:00. |
#13
Yes, coast.
#14
This feed-forward idea sounds helpful. If I understand correctly, PID alone can be done in the Jaguar via CAN, but PID with feed-forward would need to be implemented entirely in the cRIO. The Jag PID doesn't have any way to add a feed-forward value. Did I get this right?
#15
http://www.chiefdelphi.com/forums/sh....php?p=1108556 |
