Go to Post It's 9:00 Do you know where your bott is? - Michelle Celio [more]
Thread Tools Rating: Thread Rating: 52 votes, 4.98 average. Display Modes
Unread 18-03-2012, 11:46
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Alternative to PID speed control
Does anyone know of any way to control shooter wheel speed other than using PID? We are currently using PID and we are getting an oscillating error of about 5%. Any ideas how to minimize this error. (we are currently only using P. And D at all starts an oscillation.)
Unread 18-03-2012, 11:55
Re: Alternative to PID speed control
Use a flywheel, and use Jag CAN Voltage mode or do voltage compensation in the cRIO
First, look at the signal you are getting from your speed sensor (open loop) to make sure you are actually getting a clean signal.
Read the several threads here on CD that discussed PID speed control of 2012 shooter wheels.
You might want to re-read this thread:
http://www.chiefdelphi.com/forum/sho...21#post1114721
Unread 18-03-2012, 17:34
DonRotolo's Avatar
Back to humble
FRC #0832
An oscillation can be changed by changing your P factor. I would think that reducing the multiplier will help, but not knowing your mechanical setup this is just a guess. Experiment by cutting it in half and doubling it, that should tell you which direction to go.
Unread 18-03-2012, 21:04
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
You can write an equation that uses the same set motor speed voltage at a set distance using the same amount of voltage no matter how charged your battery is. See if this helps:
http://www.chiefdelphi.com/forums/sh...9&postcount=17
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 19-03-2012, 11:00
mommazzboy mommazzboy is offline
FRC #2468 (Team Appreciate)
mommazzboy is an unknown quantity at this point
This is untested, but we decided to use the PID VI coupled with a feed forward term to control output velocity.
Unread 19-03-2012, 12:03
Make sure you scale the feedforward appropriately and then clamp the result after you add it to the PID output.
Unread 19-03-2012, 18:38
baronep's Avatar
Student President
1. I have heard a lot about a "feedforward loop". Is that just an accumulator? A feedback loop? A picture is worth a thousand words
2. How does the sampling rate affect this. I am currently running the loop at 50ms using a Timed Loop. Does anyone know if adjusting this up or down would help at all?
3. Is a 5% error significant or is the inconsistency more likely rooted in a mechanical problem?
Unread 19-03-2012, 18:53
No.
A feedback loop?
No.
http://ether.comeze.com/FRC/11822/Speed_PID_dia.pdf
Unread 19-03-2012, 19:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
A feedforward term in a control loop is a term that adds to the control output based directly off of the command input or some feature thereof. It doesn't depend on any feedback, it purely feeds the command signal forward through the control loop.
For instance, in the case of controlling a shooter wheel, there's a theoretical minimum voltage necessary to run the wheel at the correct speed. Based off this, you could create a feedforward term in your control loop. Take a CIM with no reduction. 12V free speed is 5400RPM. So, if you want to run it at 2700RPM, you know you need atleast 6V output. You create a feed forward term with a gain of (12V/5400RPM). Then, your output is PID output + RPMs * (12V/5400RPM). That way, when you command 2700 RPM, you're already outputting the necessary 6V to run at that speed. Your PID loop now only has to compensate for the difference between free speed and your loaded speed. Plus, you're instantly outputting 6V without waiting for an I term to build up enough error to put out 6V for you. Basically, feedforward terms improve the response of your control loop based off features you already know about your system.
Unread 19-03-2012, 19:24
warning: If PID output is +/-1 this may not work as expected.
Unread 19-03-2012, 19:51
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
We used a very simple closed loop control that worked flawlessly. We had a jag on CAN bus with an encoder attached to the jag. We used voltage control with a voltage ramp of ~115 V/S. We queried the jag for speed, and if the speed was less than the set speed, we set max voltage. If the speed was greater than or equal to set speed, we set zero voltage. The inertia of the system kept the shooter speed within ~15 RPM of set speed at all times, and when we shot, the voltage immediately went to full for rapid spin-up.
the simplest solution that works is usually best.
Former Mentor Team 1771
Former mentor Team 4509
Unread 19-03-2012, 19:58
I've been wondering if that would work for this application. I did something very similar for an automotive actuator I worked on several years ago.
Thanks for posting that.
PS - I assume you had the Jag jumper set for coast?
Unread 19-03-2012, 21:17
martin417's Avatar
AKA: Martin Wilson
...PS - I assume you had the Jag jumper set for coast?
Yes, coast.
Unread 20-03-2012, 09:11
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
This feed-forward idea sounds helpful. If I understand correctly, PID alone can be done in the Jaguar via CAN, but PID with feed-forward would need to be implemented entirely in the cRIO. The Jag PID doesn't have any way to add a feed-forward value. Did I get this right?
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 20-03-2012, 09:19
Yes. See this post:
http://www.chiefdelphi.com/forums/sh....php?p=1108556
