Go to Post The 2016 Palmetto regional will be the most watched regional during week 0.5. - Procolsaurus [more]
  #31   Spotlight this post!
Unread 19-03-2012, 08:02
Re: Who has had a leaky battery this year?
Davis,
High on the list of reasons is someone carrying the battery by the wires. The terminal is only soldered in place under the red or black sealant. This allows the same battery to be supplied with various terminations under different part numbers.
  #32   Spotlight this post!
Unread 19-03-2012, 10:56
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
We got a battery in the KoP that was shorting...
It wasn't leaking and we couldn't find any reason.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
  #33   Spotlight this post!
Unread 19-03-2012, 11:38
yarden,
Shorting?
  #34   Spotlight this post!
Unread 19-03-2012, 17:51
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
I was definately the only person to handle the battery. Also I noticed it before I had the chance to put any wires on it.
@Yarden- did it just make random disconnectings? That is what the bad terminal battery did (tested it because FIRST refused to replace it).
As an example of the disconnecting, it would get everything booted, but the moment I pressed enable, we lost communication.
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
  #35   Spotlight this post!
Unread 20-03-2012, 08:04
Davis,
Was there any damage in the packaging?
  #36   Spotlight this post!
Unread 20-03-2012, 08:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Informative discussion. For the last two years we have mounted the battery upright in the robotic with sturdy support around it. Because I don't tug on Superman's head. (Most days.)
  #37   Spotlight this post!
Unread 20-03-2012, 09:16
Frank,
It's don't tug on Superman's Cape. Long story on how I know this.
  #38   Spotlight this post!
Unread 20-03-2012, 09:27
Frank,
http://www.youtube.com/watch?v=YQrTGE4wwwA
  #39   Spotlight this post!
Unread 20-03-2012, 11:21
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Originally Posted by Diesel Torch View Post
Last year we lost 7 batteries because of leakage... This year we upgraded to new chargers and we haven't lost a single one...
This is true; but not necessarily conclusive. We checked the suspected chargers last year for Voltage and Current draw and concluded they were in specification. We checked them at the Troy district event where we were having the issues with leaky batteries. Using new chargers with new batteries this year is inconclusive because we changed two variables, the chargers and the batteries. We would have to be using the old chargers with new batteries in order to be conclusive.
Although not 100% conclusive, the sensible conclusion seems to point to the new batteries received at the Troy district event (may have been damaged in shipment or defective from the factory). What makes it less than 100% conclusive are other potentially unknown factors (charger may have been faulty in an intermittent way - happened when we were not testing?).
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
  #40   Spotlight this post!
Unread 20-03-2012, 13:10
Captaindan's Avatar
Captaindan Captaindan is offline
AKA: Daniel
FRC #0364 (Team Fusion)
Team Role: Driver
Captaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the rough
The mks have never leaked for us though the black tops we have had problems with. When they start leaking take them to a local scrapyard and use the money to buy new mks. Handle with chemical proof gloves to avoid chemical burns
