Go to Post A Guru teaching batteries at Exide: "Do not draw your power from up here, by your terminals. You must reach down deep into your plates and pull the energy from your entire being! You must prove yourself worthy to be FIRST power cells!" - KenWittlief [more]
Unread 19-03-2012, 15:31
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Need serious help with coding!!
a basic code would be
if(joystick.getRawButton(4)
     jaguar.set(1);
else if(joystick.getRawButton(5)
     jaguar.set(-1);
else
     jaguar.set(0);
Unread 19-03-2012, 15:41
Sconrad Sconrad is offline
AKA: Connor Young
FRC #0122 (NASA Knights)
Sconrad is an unknown quantity at this point
     jaguar.set(1);
     jaguar.set(-1);
else
     jaguar.set(0);
Note: This will not create a toggle effect. If 4 is pressed, the motor will go forward and if 5 is pressed the motor will go in reverse, but it will not continue to go in that direction if you let go of the button. However, this is a good, simple solution to the problem you are facing. One thing to note about how this code will perform, if both buttons are pressed, the jaguar will go forward. One way to fix this is to replace the first line with
if(joystick.getRawButton(4) && !joystick.getRawButton(5))
It is a little bit longer, but will protect you from accidentally going in the wrong direction should you hit both buttons in the heat of competition. In order to have a true toggle effect, you will probably need a limit switch or potentiometer or other sensor to tell you when you are done going up or done going down. Hope this helps!
