Go to Post Ladies and Gentlemen I believe this is the first time a Fantasy FIRST draft has been completed before it's allotted start time! - Koko Ed [more]
Unread 17-03-2012, 16:36
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Hall Effect Sensors
So,
This this season is officially over for my team, it is time for me to learn how to code a hall effect sensor. My mentor has bought some, and now what is the best way to hook it up and derive rotations of a wheel from it?
Thanks,
Davis
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 17-03-2012, 16:44
Re: Hall Effect Sensors
Post the part number and manufacturer
Unread 19-03-2012, 07:26
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
We used a hall effect sensor for our shooter wheel this year.
Our code is at https://github.com/rbmj/612-code - shooter.{h,cpp} and launch_counter.{h,cpp} may be of interest to you. Note that we care about frequency more than rotations, so if you want rotations you can just use the stock counter class.
Unread 19-03-2012, 16:09
FRC #0539 (Titans)
The ones we got are from Electronix Express / RSR. The Part Number on that site is 11UGN3144. But I believe the general Part Number is just UGN3144.
Davis
FRC Team 539
Unread 20-03-2012, 18:54
Davis
I can't find that on DigiKey. Electronix Express doesn't give much data on the sensor either....
Edit: Found it at http://www.datasheet4u.net/download.php?id=517532
That looks good. I'd test it with a breadboard and then yeah, just use the counter class.
