Go to Post Difficult? Yeah. Extremely difficult? Some parts. Doable? It's been done. - [more]
Unread 19-03-2012, 19:13
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Wiring Fans
Hello all,
We have two fans we want to hook up, with one relay.
Is it legal to have two fans powered by one relay?
if not, is there a way to make it legal with some custom circuit?
Unread 19-03-2012, 19:18
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Re: Wiring Fans
Our team has never used fans, but I have never thought about using a relay for fans, I had just assumed that the way to wire it would be using Digital/Analog setup. Would you be able to do that?
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 19-03-2012, 19:24
ksafin's Avatar
AKA: Kirill Safin
Re: Wiring Fans
Never used Analog.
Enlighten me? (Rookie team)
Unread 19-03-2012, 19:46
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Wiring Fans
According to rule [R46]:
Exception: Multiple low-load, pneumatic solenoid valves or lights may be connected to a single relay module. This
would allow one relay module to drive multiple pneumatic actions or multiple lights. No other electrical load can be
connected to a relay module used in this manner.
Fans are low-load. However, most cooling fans can be wired directly to the PD board. Just remember [R42]:
D. Only one wire shall be connected to each WAGO connector on the PD Board. If multi-point distribution of
circuit power is required (e.g. to provide power to the three KOP breakout boards via one 20-amp circuit),
then all incoming wires must be appropriately spliced into the main lead, and only one lead inserted into the
WAGO connector to connect the circuit.
Unread 20-03-2012, 08:36
Re: Wiring Fans
Kirril,
Fans do not need to be wired to Spikes. You can splice the leads together and wire directly to an output on the PD. The fans will run all the time the robot is powered, but generally fans draw very little current.
