Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Unread 19-03-2012, 19:42
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
Re: Vision Tracking Help
I think I understand this in words, but putting it into labview is the difficulty. I think you are saying if the camera is mounted center on the turret then your target might have an coordinate of (0, 5) and as you move the coordinate would change but we want the program and the turret to do everything in its power to keep the X-Coordinate at 0. The Y may change as you get closer or move further away, but the program is trying to keep the X the same to keep it centered on the turret.
Now making that a reality is where I am going to struggle.
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 19-03-2012, 20:52
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Try something similar to this.
You'll want to use the X coordinate from the camera as the process variable to a PID controller (since this will change with the rotation of the turret). Your setpoint should be the center of the image (where you want the target to appear). This can be found by dividing the X resolution of the image by two. Note that this also assumes that the camera is mounted exactly on the center of the shooter - you might have to tweak the setpoint to make it mesh with your system. You'll need to tune the PID constants in my snippet - since they're the default values. There are other threads around for help on PID gain tuning (just search for them).
Unread 19-03-2012, 22:46
If you are using the Target location from the LV example, it is a -1 to 1 coordinate with 0 in the center, not 80. If you are using a more raw version, width/2 would be the right target for the PID.
Greg McKaskle
Unread 20-03-2012, 20:16
yelk11 yelk11 is offline
FRC #3414
yelk11 is an unknown quantity at this point
how do you add another camera that is not an axis camera. mine is a trendnet tv-IP110/A
