Go to Post Steal from the best, and then invent the rest! - dlavery [more]
Unread 19-03-2012, 20:52
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Vision Tracking Help
Try something similar to this.
You'll want to use the X coordinate from the camera as the process variable to a PID controller (since this will change with the rotation of the turret). Your setpoint should be the center of the image (where you want the target to appear). This can be found by dividing the X resolution of the image by two. Note that this also assumes that the camera is mounted exactly on the center of the shooter - you might have to tweak the setpoint to make it mesh with your system. You'll need to tune the PID constants in my snippet - since they're the default values. There are other threads around for help on PID gain tuning (just search for them).
Unread 19-03-2012, 22:46
If you are using the Target location from the LV example, it is a -1 to 1 coordinate with 0 in the center, not 80. If you are using a more raw version, width/2 would be the right target for the PID.
Greg McKaskle
Unread 20-03-2012, 20:16
yelk11 yelk11 is offline
FRC #3414
yelk11 is an unknown quantity at this point
how do you add another camera that is not an axis camera. mine is a trendnet tv-IP110/A
