Go to Post I think Dave was tired...he kept muttering something about "eviscerating" someone. Heidi seemed to be doing most of the talking. Actually, after talking with 29,000 people, I think she lost her voice. Or maybe Dave "eviscerated" it.... - RoboMom [more]
Unread 06-01-2003, 21:05
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Converting Inventor Files To Max
How exactly can you put Inventor 5/6 files into Max 4.2/5??? Is one method transfering them into CAD, and then from CAD to Max?? I think that's how we did it last year, but I'm not sure, and is there an easier way to do it?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 06-01-2003, 21:46
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Try Deep Exploration.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 06-01-2003, 21:49
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Can Inventor import or export IGES files? If I remeber correctly, 3ds max can import that type.
Unread 06-01-2003, 22:04
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
IGES
I'de use IGES files, but dont save an assembly as an IGES file because i've tried that and it made it one solid.
Purdue Alumni
Cummins, Inc.
Unread 07-01-2003, 08:23
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
Re: IGES
iges and max do not work together at all so do not export to an iges. An entire solid is extremely had to work with and is a waste of time in the end.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 07-01-2003, 15:05
Okay... but is there a plugin or something I need to go straight from Inventor to Max??... or do I have to go from Inventor to CAD to Max?
Unread 07-01-2003, 17:42
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Doesn't Inventor export to 3DS?
EDIT: Just checked.. and it doesn't. You would think they would have tried to make Inventor quickly compatible like that. Use IGES.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 07-01-2003, 22:34
mzb295 mzb295 is offline
#0048 (Delphi E.L.I.T.E.)
mzb295 is an unknown quantity at this point
Inventor has plug-ins for 3ds max that allow a user to directly import .ipt and .iam files. Inventor 5 works with 3ds max 3 and 4. Inventor 6 also works with 3ds max 3 and 4. You must install sp1 for inventor 6 and download the updated plug-ins for 3ds max in order to import files into 3ds max 5. Both of the updates can be found at http://support.autodesk.com/enu/Homepage.asp
On the left side of the page click on Download Updates and Drivers
In the center screen
Product: Autodesk Inventor
Release: 6
Category: Updates and Maintenance
Click on GO
you need
Autodesk Inventor® 6 Service Pack 1 (All versions)
and
Updated Autodesk® VIZ and 3ds max™ Plug-in for Autodesk Inventor® files
Follow the instructions found in the readme files.
Max imports the files as a perfect editable mesh. Assemblies import as individual editable meshes.
I hope this helps,
Dennis
Unread 08-01-2003, 08:04
Soukup's Avatar
Animation Guru
AKA: David Soukup
didn' that one guy last year at nationals show an easier way?
Team 74 Alumni
Unread 16-01-2003, 21:39
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
This came up last year, I will look through te archives for it
Tyler
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 17-01-2003, 00:03
AJ Quick's Avatar
I hope there are easier better ways! I just sent a IGES from Inventor to Max, and max could hardly move is was going so slow.
Unread 18-01-2003, 17:20
One would think Autodesk would have resolved this problem by now by putting addition plugins/software in with the software they send us since they know we're going to be using Max to animate it. It almost seems like common sense.
Unread 18-01-2003, 23:23
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
MD can export to 3ds.
Anthony Rinaldi
Team 1132: 2003
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
FIRST MAX Animation Tutorials Robby O 3D Animation and Competition 2 01-02-2002 22:53
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
