Go to Post amazing stuff. - Specialagentjim [more]
Unread 07-01-2003, 08:38
I will go out on a limb here and say this, "if you can't run at least two matches on a battery you need to look at your mechanical design." There are a lot of factors contributing to battery drain but an efficient design should not drain the battery during one two minute match. If it does, your robot has either come dangerously close to reset or has reset during the match.
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
