Go to Post Remind me again. Why do we let the GDC hold us captive to these hints year after year? - jholman [more]
  #61   Spotlight this post!
Unread 19-03-2012, 21:18
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Team Fusion #364, Bayou Regional, FMS Woes
Originally Posted by RyanN View Post
We're still reviewing data and trying to piece things together.
Did you see this post in 330's thread?
Originally Posted by MrClintBarnes View Post
I was FTAA at the regional at Utah this last week, and we were having similar problems. The FTA found that every team on the field had high trip times (>30ms) when there was a team with a D-Link running firmware version 1.4.
We has the CSA downgrade those bridges to v1.2 of the firmware and all of the trip times went back down to normal. I am not sure if this is the same problem that everyone else was having, but downgrading the firmware on any of the older bridges running 1.4 seemed to help.
-Clint
Just to throw that out there.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
  #62   Spotlight this post!
Unread 19-03-2012, 22:10
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Originally Posted by nukemknight View Post
Very slim chance considering FMS uses WPA. Thats the purpose of the radio kiosk that all teams must use to re-program their radios at each event. The WPA keys are randomly generated by FMS at each event so you team's key will change between each event. The WPA key list is not available to teams.
The fact that it is WEP does NOT make it secure... in fact, some people joke that it is easier to crack WEP at someone's houls (and faster) than to get up and ask them. All commercial wifi setups have flaws. For example, I have seen backtrack 5 crack my home wifi (linksys a/b/g router, set to WEP temporarily) in under two hours. Via a laptop. With WPA2, it took 4 (used the WiFi protected setup vulnerability). A sufficiently determined team COULD crack the encryption in a relatively short timeframe. Or, they could use any of the other specialized linux penetration testing distros. And if the WPA list key is not avaliable to teams, how hard would it be to imitate the FMS setup? (change MAC address on router, set up a network, log attempted connections and passwords)
Yes, I seem to have put too much thought into this. I do not intend to be the kind of person who would do this, however.
  #63   Spotlight this post!
Unread 19-03-2012, 23:10
abbyjcox's Avatar
abbyjcox abbyjcox is offline
AKA: Abby Cox
FRC #0364 (Team Fusion)
Team Role: Animator
abbyjcox is an unknown quantity at this point
Whatever the problem is....I just hope that it is fixed IF/when we go to Lonestar...I know that EVERYONE on the team worked our butts off to build what we all agree is the best robot we have ever made.. and it stinks beyond belief to see it all go to waste over a problem that wasn't even our fault.. Personally I am kinda disappointed with FIRST for how unhelpful they were, they above all others should be the prime example of gracious professionalism and this time they fell short.. However, I am very proud of my team mates and how they conducted themselves through all of our issues and I know that even if we are not able to compete and put all of our hard work to good use, that all that hard work was not completely wasted because we all learned A LOT this year, and still had fun in the process despite the hard time we encountered at the regional.
  #64   Spotlight this post!
Unread 20-03-2012, 01:14
You might find it enlightening to consider the total amount of time a given team's wireless network is even active at a regional.
  #65   Spotlight this post!
Unread 20-03-2012, 02:13
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
And again, as I understand it...
Why try to crack the WPA or WEP, whatever it is, encryption when you can simply reprogram your router with another teams number?
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
  #66   Spotlight this post!
Unread 20-03-2012, 09:40
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
But the FMS would detect duplicate IP addresses because I doubt the install script FIRST uses changes the machine address. So if something nefarious happened, I doubt it involved re-programming a router with the same team number (by FIRST) - which means they would have to hack comms to get the WPA keys. And a MITM attack seems too far-fetched for FIRST students to pull off.
Nope, there has to be another reason. We were a few spots down from you in the pits. I wish I new you were having trouble, we could have swapped some parts around and eliminated some causes. It is so unfair that you had an undiagnosable problem like that! Any luck with Greg?
  #67   Spotlight this post!
Unread 20-03-2012, 10:08
Greg is digging through the data I do have and I'm looking for more. I'm waiting on log files from another team at Bayou. If you have access to the DS computer, I'd really like to compare aspects of the files between teams with no perceivable issues and ones with issues. PM me if you are able to assist.
I'm also collecting log files as I force specific types of failures. I'm not sure if or when it will be known what caused the failures, but I'm learning of other things that would be nice to log and ways to better diagnose if this happens again.
Greg McKaskle
  #68   Spotlight this post!
Unread 20-03-2012, 10:14
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Greg, forgive my ignorance, but I'll be telling my programming team about this.
Are there some instructions or something I can look up to help them find the log files?
James Tonthat
Mechanical Engineer, RackSolutions
Texas Torque - 2009-2014
Robowranglers - 2015-
  #69   Spotlight this post!
Unread 20-03-2012, 10:59
Command67's Avatar
Command67 Command67 is offline
I'm a minimalist at heart.
AKA: Logan
Command67 is on a distinguished road
I don't think the firmware's the problem. When we looked on Saturday at the router's information during regional it said v.1.21.
NIXON'S THEOREM: The man who can smile when things go wrong has thought of someone he can blame.
  #70   Spotlight this post!
Unread 20-03-2012, 11:21
mcristina444 mcristina444 is offline
FRC #2078 (Robotic Ooze)
mcristina444 is an unknown quantity at this point
We attended the Bayou Regional and almost every time we we connected to Blue 3 we lost connection. The computer said we were connected to the FMS but the communication and robot code lights were off. The RSL never stopped blinking. Also once we were connected to Blue 1 and headed in front of the Blue 3 side ( by the ref table) and lost connection. After speaking with officals they stated that our battery dropped below 8 volts before dropping out, but the battery level on the dashboard was steady. Just my 2 cents.
2078 Driver
  #71   Spotlight this post!
Unread 20-03-2012, 11:27
RyanN's Avatar
RyanN
The log files are located in:
C:\Users\Public\Documents\FRC\Log Files
You can view them using the Driver Station Log File Viewer located in:
64-bit Operating System
C:\Program Files (x86)\FRC Driver Station
or
32-bit Operating System
C:\Program Files\FRC Driver Station
Controls Mentor
@rnazaretian
Previous teams:
  #72   Spotlight this post!
Unread 20-03-2012, 12:07
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
2078 Driver
...hmmmm
George Wallace (SPAM'er, Exploding Bacon and Orlando emcee) said something interesting last night at our SPAM meeting. He was telling me that teams were reporting a dead spot on the field (Orlando regional): blue zone, near the scorer's table. Our freshman IT whiz-kid was telling me that, when we walked down to the field for the Finalist medals he took a peak at the field hardware. Apparently there is a cluster of high end routers located at the scorer's table in that corner. I was just talking to one of our CE/EE's, here at Belcan, who did a lot of work in the RF lab at FAU. Locating a group of routers in a cluster can and will cause near-field cancellation.
... yet another tidbit ...
Eric
Don't PANIC!
S. P. A. M.
  #73   Spotlight this post!
Unread 20-03-2012, 12:22
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by EricS-Team180 View Post
...hmmmm
Eric
It's a single AP with 6 antennas (if you look closely, there are 3 for 2.4ghz and 3 for 5ghz).
In the range we are talking about (no more than 50' with no solid obstructions), 802.11 should have no problems with signal strength assuming the bridge is mounted well.
Kettering Motorsports
  #74   Spotlight this post!
Unread 20-03-2012, 12:31
Generator of Entropy
FRC #2973 (The Mad Rockers)
Originally Posted by apalrd View Post
...802.11 should have no problems with signal strength
Seems to be the answer everyone is getting from the FTA - there shouldn't be a problem, therefore it isn't a problem, therefore it's your problem.
I guess we should just ignore all the data points that multiple, experienced, highly competitive teams are providing, since there shouldn't be a problem.
  #75   Spotlight this post!
Unread 20-03-2012, 13:33
apalrd's Avatar
More Torque!
VRC #3333
I've seen this thread mention many reasons other than 802.11 signal strength as the cause of issues. I only mentioned signal strength, in relation to a post questioning possible issues related to the design of the field AP.
