Go to Post The robots are just vehicles taking kids on a ride to STEMville. - FTC5110 [more]
Unread 20-03-2012, 17:21
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Re: 5th motor woes...
Originally Posted by RufflesRidge View Post
Your Digital Sidecar needs to be powered with 12V from a circuit on the Power Distribution Board with a 20A Breaker. The BAT LED on the Digital Sidecar should be brightly lit.
this. I have heard reports that the control cables going to PWM's have enough power coming from the cRio to power 4 speed controllers, but if you add a 5th they do not have enough juice. Therefore, you need to make sure that you are powering you sidecar as described above. There were connectors for the sidecar provided in the KoP. (I believe they're called WAGO connectors?)
www.sharkattack744.com
