Go to Post So measure not by the masses, but by the sparks that you generate. - Kims Robot [more]
Unread 20-03-2012, 16:41
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Unhappy 5th motor woes...
This year, I convinced my team to let some of our electrical equipment be part of our spare parts so I could finish a last little bit of programming. I ran into a fairly large problem though, our current design needs five motors running: two for the drive train (CIM), one for a ball intake system (Window Motor), one for a rubber band elevator system (CIM), and one more to use for an arm (Window Motor). When I have only the first four, everything works as expected, but when I add the arm, everything falls apart, complete with flashing yellow lights on the speed controllers. I don't do anything with that motor, I simply open the reference in begin and close it in finish, but somehow opening the reference causes this problem. I've tried other PWM inputs and different names of the reference (Arm, Pole, Bar, even Blag!!) and keep getting the same result, but if I simply delete it, everything is fine. Any ideas on the problem or ideas for a solution?
I am programming using Labview, I didn't know if this was a problem specific to it or not, so I decided to post this in programming. I don't know anything about how other languages work, so my apologies if it doesn't make any sense outside of labview.
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 20-03-2012, 16:45
Re: 5th motor woes...
Your Digital Sidecar needs to be powered with 12V from a circuit on the Power Distribution Board with a 20A Breaker. The BAT LED on the Digital Sidecar should be brightly lit.
Unread 20-03-2012, 16:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Just to clarify, you're saying you have the 5th motor electrically plugged in and wired in at all times. With the 5th motor wired in, your code works if you don't open a reference to it, and everything stops working when you do open a reference. So the only difference is you changing the code, nothing electrical. Is that right?
Also, what are your diagnostic light on the dashboard doing when the robot doesn't work? Do you have comms? Robot Code? Are you getting a watchdog error?
Posting your code would also be helpful for trouble shooting.
Unread 20-03-2012, 17:12
the programmer's Avatar
the programmer the programmer is offline
AKA: Erik Orlowski
FRC #2830 (Riverside Robotigers)
the programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud of
Can you post a copy of your program and a picture of your control board?
2006-2008: FLL Student
2009-2014: C.O.R.E. 2062
2010-?: FLL Referee
2015-?: Riverside Robotigers 2830
Unread 20-03-2012, 17:21
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
this. I have heard reports that the control cables going to PWM's have enough power coming from the cRio to power 4 speed controllers, but if you add a 5th they do not have enough juice. Therefore, you need to make sure that you are powering you sidecar as described above. There were connectors for the sidecar provided in the KoP. (I believe they're called WAGO connectors?)
www.sharkattack744.com
Unread 20-03-2012, 18:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
That's the correct term.
Unread 25-03-2012, 10:11
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Was the problem -solved?
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
