Go to Post If you are "retiring" the old ball, make all the lights green, hang it 8 feet in the air, line up a bunch of 'bots and let 'em shoot poofs. RoboPinata! (warning kids - don't eat the "candy" that falls out!) - Taylor [more]
Unread 20-03-2012, 20:02
yelk11 yelk11 is offline
FRC #3414
yelk11 is an unknown quantity at this point
Arrow how to add a non-axis camera
I have a camera, however it is not an axis camera how do i get an image from it an donto the dashboard?
the camera is a trendnet camera
Unread 20-03-2012, 21:11
Re: how to add a non-axis camera
What model? Is it a network ("IP") camera?
The dashboard is written to connect to a camera that implements the Axis protocols via an Ethernet connection. If you want to use a different camera, you're responsible for figuring out how to view its image.
Most network cameras can be viewed in a simple web browser. That should be easy enough (unless you're using the Classmate's "Driver" account).
Unread 20-03-2012, 23:11
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
shift-Esc, new task, iexplorer.exe
Unread 21-03-2012, 00:23
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
I think you mean Ctrl-Shift-Esc
Jason
Unread 21-03-2012, 14:08
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Hi, I am from the same team. Here is the thread that I posted with more information: http://www.chiefdelphi.com/forums/sh...on+axis+camera
