Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 20-03-2012, 23:42
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: By the book: wifi-less scouting?
Originally Posted by slang800 View Post
If you read section 4.3.1 Robot Wireless Control in the rules, you will see that wireless networks are prohibited anyway.
This is probably made to prevent the wireless networks from interfering with the FMS, but could also be due to the fact that many arenas have vendor-supplied wifi and could have urged FIRST to make this rule. Either way, you shouldn't setup a wireless network at a event (unless it's a bluetooth PAN).
Because of this rule, our team has setup a completely wired network using a Apache2 server running on a laptop and a router to connect to other laptops which scouts use. However, we ran into issues with getting power at our last regional and needed to fall back on our paper system.
That doesn't mean you can't connect to one of someone else's open networks (possibly from outside the arena) without internet access, and use it as a way to communicate between your scouts. That would be within the spirit of the rules right?
[IMG] code is Off
