Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 21-03-2012, 08:50
BSpar29 BSpar29 is offline
FRC #1884
BSpar29 is an unknown quantity at this point
Team 1884 Scouting Resources
I am happy to share with you all of team 1884 the Griffins' scouting resources, that worked for us very well during our regional this year. We have three documents. The first one is a scouting sheet, that is filled out by hand, and is focused on one team during each match. The second one is an excel spreadsheet which directly matches up with the scouting sheet, and is inputted manually. This spreadsheet calculates averages for teams, and demonstrates the most important data points in an easy to read format. The third sheet is to give to the drive team, and consists of the most important facts about each team and a suggested strategy section. If you choose to use it, I hope it serves you well. If you have any questions, don't be afraid to ask. Same with any suggestions. Good luck in rebound rumble!
Unread 21-03-2012, 08:58
FRC #1884
Re: Team 1884 Scouting Resources
By the way, you will have to replace the team names manually. If you look at the formula's you can get a hold of how it works and it is quite simple.
Unread 23-03-2012, 21:18
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
My team is looking at editing the match scouting sheet very slightly, keeping it almost the same, and using it for our scouting sheet. Can we do this?
Unread 23-03-2012, 21:44
FRC #1884
Of Course! Good Luck!
[IMG] code is Off
