Go to Post I'm here to unintentionally offer insightful quotes. - Jeff Waegelin [more]
Unread 21-03-2012, 13:49
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
What is CAN
Hi all -
I've seen a number of posts on CD about CAN and have been a loss. If anyone can explain CAN, I'd be appreciative.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 21-03-2012, 14:36
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: What is CAN
Originally Posted by MysterE View Post
Hi all -
CAN stands for "Controller Area Network" and is a vehicle communication system developed by Bosch. Bosch developed CAN as a standard method of communication between all of the various controller modules in a car.
CAN works very well as a method to communicate between multiple control modules. Since the Jag speed controllers have their own on-board processing, you can think of them as individual control modules which you can communicate with using CAN.
More info can be found here: http://en.wikipedia.org/wiki/CAN_bus
Unread 21-03-2012, 14:37
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: What is CAN
Can itself is just another way to communicate with Jaguar motor controllers (outside of FIRST, it is used for a lot more, like all of the sensors in a car for example). Compared to the alternative, PWM, CAN allows for a lot more information to be sent between devices.
The real importance of CAN stems from the fact that, when using CAN, the jaguars' processors can be used to preform tasks that would otherwise be dealt with by the cRIO, notably PID control. PID control utilizes feedback to react to situations so that the desired output matches the actual output. That is, instead of guessing what PWM duty cycle will get a certain speed, PWM control will adjust the duty cycle to ensure that that speed is met.
Using the jaguars' PID controls allow one to control speed, position, average voltage, and current (I'm not sure that the last 2 are technically PID, but they are still available if CAN is used). By extension, these control modes, when properly utilized, can be used for things such as ensuring that your robot moves in a straight line in autonomous, or for regulating shooter speed and angle.
