Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 21-03-2012, 21:00
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: File Size Compression
Likewise, I have not done any animation, but have spent time with videos.
The software you are using is probably outputting/exporting to a high definition lossless format. You may want to see if you can reconfigure the settings to a lower quality and try again. there are also a lot of video converters on th internet that will compress or lower the resolution for you. Just note that as you decrease the file size you will lose some crispness and clarity. However, I have found that most people can't tell (other than the creator(s)).
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 29-03-2012, 13:35
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Just to remind you, the files must be Quicktime .mov with either H.264 codec or MPEG-4 - not .avi. We reduced ours down to 47MB by choosing H.264 and limit the kbytes/sec. It is a tight squeeze.
