Re: 0=-1 (Calculus Puzzle)
Peck, sorry to tell you but i doubt ull win haha
Although ether, can you prove or disprove Riemann Sums? Now that would be cool. |
fas est dividere cuius rei demonstrationem mirabilem sane detexi. Hanc marginis exiguitas non caperet
ingles por favor sinor
1) *Inglés or favor señor.
2) according to google translate: It is a wonderful demonstration of what share of corruption. Shortness of this margin does not take but that seems like it was lost a bit in the translation ![]() It is actually taken from Fermat who wrote about a theorem (a^x + b^x = c^x has no integral solution set a,b,c for any integer value for x greater than 2) in the margins of a book in 1637. It is actually the description of the proof for this theorem which he came up with and it translates more accurately to Quote:
Over the years people proved that it held true for specific exponents. It wasn't until 1995 that it all came together in an extremely complex proof that was probably not what Fermat had in mind, but a general proof of the theorem non the less. Last edited by PAR_WIG1350 : 21-03-2012 at 23:28. |
Well played, Ether. |
#7
my computer is annoying whenever i try to insert alt symbols. also, i was using spanish, not latin and por was correct.
#8
One that's not so hard to disprove is as follows: 0 = (1 - 1) + (1 - 1) + (1 - 1)... Rearrange parenthesis: 0 = 1 + (-1 + 1) + (-1 + 1) + (-1 + 1)... 0 = 1 + 0 + 0 + 0.... 0 = 1 (Ether's going to get this oh-so-fast...) //Andrew |
#9
after you rearrange parenthesis, you should have the one at the end that was freed up, therefore 0 = 1 + (-1 + 1) + (-1 + 1) + (-1 + 1)... ...-1 0 = 1 + 0 + 0 + 0... ...-1 0 = 0 |
#10
Ah, ok. Not entirely how I was trying to communicate it, but I guess being an infinite sum invalidates that anyways.
#13
The problem with the above "proof" is that the associative law of arithmetic is not universally valid for infinite sums. So you aren't allowed to re-arrange (or remove) the parentheses. Last edited by Ether : 23-03-2012 at 22:20. |
#14
I thought that because the series doesn't converge, it doesn't equal zero to begin with. //Andrew |
#15
(1 - 1) + (1 - 1) + (1 - 1)... ... does converge. It converges because of the parentheses. The term that is being repeatedly added is (1-1). It is equal to zero. If you remove all the parentheses, so that you have 1 - 1 + 1 - 1 + 1 - 1 ... then you are alternately adding plus or minus 1, so the sum never converges: it oscillates between 1 and 0. The error was re-arranging the parentheses. The associative law does not always hold for an infinite sum: You cannot re-arrange the parentheses in an infinite sum unless certain criteria are satisfied. |
