Go to Post Without mentors, you wouldn't even be participating in FIRST. Your team wouldn't exist, and FIRST as a program wouldn't exist. If it did, it'd just be another form of a science fair. - Cory [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 21-03-2012, 22:34
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: 0=-1 (Calculus Puzzle)
fas est dividere cuius rei demonstrationem mirabilem sane detexi. Hanc marginis exiguitas non caperet
ingles por favor sinor
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 21-03-2012, 23:09
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
1) *Inglés or favor señor.
2) according to google translate: It is a wonderful demonstration of what share of corruption. Shortness of this margin does not take
but that seems like it was lost a bit in the translation
It is actually taken from Fermat who wrote about a theorem (a^x + b^x = c^x has no integral solution set a,b,c for any integer value for x greater than 2) in the margins of a book in 1637. It is actually the description of the proof for this theorem which he came up with and it translates more accurately to
I have discovered a truly marvelous proof of this, which this margin is too narrow to contain.
unfortunately his proof seems to have disappeared off the face of the earth, assuming he even wrote it down.
Over the years people proved that it held true for specific exponents. It wasn't until 1995 that it all came together in an extremely complex proof that was probably not what Fermat had in mind, but a general proof of the theorem non the less.
Unread 21-03-2012, 23:30
Sounds like the classic "I have discovered a truly marvelous proof of this, which this margin is too narrow to contain" from Fermat. Which, on investigating the Wikipedia entry on Fermat's last theorem, is exactly what it is.
Well played, Ether.
Unread 21-03-2012, 23:33
Well played, Ether.
Thank you
Unread 22-03-2012, 07:11
Peck's Avatar
my computer is annoying whenever i try to insert alt symbols. also, i was using spanish, not latin and por was correct.
TEAM 1619
Unread 23-03-2012, 16:57
RoboDesigners's Avatar
RoboDesigners RoboDesigners is offline
VRC #2190 (RoboDesigners)
RoboDesigners will become famous soon enoughRoboDesigners will become famous soon enough
Has this turned into a thread of trying to find a math trick that Ether doesn't know how to work it? If so, i want a chance to disprove it before he dose .
I have an article here one of my math professors gave me that has a dozen "proofs" that 1=2. (She gave me this after I showed her my "proof," which happened to be in the article... I guess I didn't come up with it first...)
One that's not so hard to disprove is as follows:
0 = (1 - 1) + (1 - 1) + (1 - 1)...
Rearrange parenthesis:
0 = 1 + (-1 + 1) + (-1 + 1) + (-1 + 1)...
0 = 1 + 0 + 0 + 0....
0 = 1
(Ether's going to get this oh-so-fast...)
//Andrew
Visit my website! www.RoboDesigners.com
VRC Team #2190
Twitter: @RoboDesigners
Unread 23-03-2012, 17:19
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
0 = 1
//Andrew
Not if the other Andrew gets there first!
after you rearrange parenthesis, you should have the one at the end that was freed up, therefore
0 = 1 + (-1 + 1) + (-1 + 1) + (-1 + 1)... ...-1
0 = 1 + 0 + 0 + 0... ...-1
0 = 0
Unread 23-03-2012, 17:52
Nate Laverdure's Avatar
FRC #2363
Originally Posted by Dusk Star View Post
after you rearrange parenthesis, you should have the one at the end that was freed up...
But can't the one at the end just be moved into the next (1 - 1) term?
Unread 23-03-2012, 18:49
0 = 1
Sorry, I was offline all day.
The problem with the above "proof" is that the associative law of arithmetic is not universally valid for infinite sums. So you aren't allowed to re-arrange (or remove) the parentheses.
Unread 23-03-2012, 18:51
There is no 1 "at the end". It's an infinite sum.
Unread 24-03-2012, 14:30
Dusk Star's Avatar
AKA: Andrew
Ah, ok. Not entirely how I was trying to communicate it, but I guess being an infinite sum invalidates that anyways.
Unread 24-03-2012, 15:20
Hmmm... that's different than what I was going to say... (the article I have doesn't list the answers...)
I thought that because the series doesn't converge, it doesn't equal zero to begin with.
//Andrew
VRC Team #2190
Unread 24-03-2012, 15:47
... does converge. It converges because of the parentheses. The term that is being repeatedly added is (1-1). It is equal to zero.
If you remove all the parentheses, so that you have
1 - 1 + 1 - 1 + 1 - 1 ...
then you are alternately adding plus or minus 1, so the sum never converges: it oscillates between 1 and 0.
The error was re-arranging the parentheses. The associative law does not always hold for an infinite sum: You cannot re-arrange the parentheses in an infinite sum unless certain criteria are satisfied.
Unread 24-03-2012, 20:45
AKA: Alan Wells
FRC #1350 (Rambots)
The lack of a "p" was a typo, also, I don't like using alt to insert symbols either, but if you use google translate to enter the text the symbol keys (;',./[]\=-) are used to input special letters like vowels with accents
Also, nobody has attempted to figure out this one yet
167 = -53
No illegal operations were performed, slightly non-standard
Unread 26-03-2012, 10:51
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I have an article here one of my math professors gave me that has a dozen "proofs" that 1=2. ...
Would you be willing to share this article?
Back in college years, my two buddies and I decided to go to Las Vegas for spring break. We piled into my Chevy Cavalier station wagon (jealous?) and headed West.
About 4am, we got to the point where we were all falling asleep, none of us were able to drive, and the car was too small to comfortably fit three guys. We found a small motel in Kansas, paid $30 for a room ($10 each), and retired for the night.
The clerk was filling out his books when he realized the motel had a policy of $25 per night after 1am. He took five $1 bills and headed to our room. Along the way, he realized we were not going to be able to split five bucks equally among the three of us. He shoved two of the singles in his pocket, gave us each a dollar, and that was that.
Here's the issue:
We were initially charged ten dollars a piece - total of $30.
After the clerk realized his error, the room charge was $25. We paid $9 apiece ($10 - the $1 that was returned) for a total of $27; he put two dollars in his pocket for a total of $29.
29 = 30 ?
Hi!
