Re: Yet another Android Scouting App
That and his 1 post and no team has me saying, "Delete this thread mods." |
Since you don't like it (and neither does my son), I'll ask the mods to change it, but I need a clever suggestion. "make robot" (which give you: make: *** No rule to make target `robot'. Stop. but no one would get that. If you can have a 140 character username, then how about this: function(a,b,c,d,e){return d+=c, e=a|b<<d,d<0|a&b<<d&&(a=e= parseInt((a|b<<c).toString(d=32) .replace(/v/,""),d),b=new Date%2?1:3), [a,b,d,e]} (Plays tetris - https://gist.github.com/1672254) but would be quite hard to type as a login. OK, back to the app. Some screenshots are attached. Run it in an emulator if you're worried. Cameras don't work on the 2.x (2.2 and greater) emulators. It'll run in 2.1 (or probably 1.6) but the ICS (4.0) emulator is a better choice. Last edited by rm -rf / : 22-03-2012 at 12:57. Reason: Camera woes |
Your username's fine, but it just makes a download in your first post a lot more suspicious. That makefile interaction would make a nice signature, however
Well his name is only harmful if you've got r00t
I have always wondered how many people on here were linux junkies such as myself. and if we can have 140char names, can mine be along the lines of javascript:while(true){alert("2168 swag");};; also sudo make me a sandwich (yes, a Makefile is present) |
I don't know. If you're enough of a geek to be running Linux on a regular basis then you probably know the "rm" command and would be smart enough not to run it and not to randomly run people's usernames from the command lines (although I'm fairly sure "andreboos" is safe).
As for sandwiches, you should already have one. $ make sandwich make: Nothing to be done for `sandwich' (Is that an "interesting" make artifact, a tip of the hat to XKCD or an old easter egg?). BTW, I'm not going to try it, but I fairly sure that you can do significant damage without root access, in particular, I think you could end up trashing your home directory. rm -rf is a really dangerous command, especially if you're root but even if you're not. rm is "remove" -r is recursive and -f is force, don't ask any questions. The final argument is the directory you want to apply it to / is the root of your disk. Common newbie error is to run rm -rf on a directory and then notice that . and .. are still there, so then run "rm -rf .." (probably very destructive). Last edited by rm -rf / : 22-03-2012 at 16:08. Reason: Warning... |
