Go to Post For those of you that think the kit chassis is too weak... It is tough stuff. Those of you that say it is too weak, just do not know what you are talking about. - Paul Copioli [more]
Unread 22-03-2012, 01:20
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Digital Side car short
Hi what ended up happening was that there was a short at the plug of the incoming 12v source to the DSC but now on my the battery light turns on and the 5v and 6v lights won't. I know that everything else works because I swapped our the DSC for another and it worked. But I simply don't want to trash it if it has a fix. I have a multimeter, ( even though I don't know how to use it) im a programmer not an electrician but my soldering skills are pretty good so could it be possible to find the bad component and replace it?
Unread 22-03-2012, 03:00
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Digital Side car short
It might be; I myself am also I programmer but I do electrical too. With enough knowledge or instructions on how to fix your side car, you should be able to do it. If I was you I'd get in contact with the electrical people on your team and have them do it.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 22-03-2012, 03:05
FRC #4210
Well the problem is we don't have electrical people. Our electrical knowledge consists of knowing how to connect cables.
Unread 22-03-2012, 03:20
RC3's Avatar
RC3 RC3 is offline
AKA: Robert Carter
no team (2928 alum)
RC3 is an unknown quantity at this point
is fixing it necessary for your robot to run at competition?
Unread 22-03-2012, 03:58
For your replacement DSC, make sure you have stripped the wires just enough to fit inside the wago connector (power connector) but not more than that. The power wires are very close together so if you strip it too much they can short easily. Leave no exposed wire.
Unread 22-03-2012, 05:31
What do you mean by "everything else works"? Is it just the 5V and 6V LEDs that don't work, but the e.g. PWMs and GPIO work? Or is it that the the only thing on the DSC that works is the battery light, and everything else is toast?
Is it possible that it was plugged in with the power reversed?
Was the short before or after the DSC?
