Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 22-03-2012, 15:09
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
[FTC]: Teleop - that creates an auton?
Has anyone explored writing a tele-op code that would store commands and translate those commands to an autonomous program?
Unread 03-04-2012, 16:34
techappetite's Avatar
techappetite techappetite is offline
AKA: Titus
FRC #3528 (Up Next)
Team Role: Marketing
techappetite is on a distinguished road
Lightbulb Re: [FTC]: Teleop - that creates an auton?
I have indeed played with this idea in the past... however, I haven't had the time to actually try to do this. I guess it could be possible if you could read the values of the encoders on the motors and log that in a file. You could then write a program that takes the raw data and converts that into autonomous code.
Check out Tele-op Catalyst for ROBOTC, a free program which writes tele-op/usermode programs for you!
http://tituswoo.com/project/catalyst
Unread 03-04-2012, 17:48
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
Several teams have done this in the past & while we've been able to make it work, the consensus seems to be that a traditionally programmed autonomous is the better way to go.
Please see this thread on the ROBOTC forums for more details:
http://www.robotc.net/forums/viewtopic.php?f=52&t=4227
Unread 06-04-2012, 19:27
Enderbot's Avatar
Enderbot Enderbot is offline
FTC #5484 (Enderbots)
Enderbot is an unknown quantity at this point
Well what our developer did to create the program was use a simple Teleop program that shows all the encoder values. Wrote each value down after each step and created it from that.
Take crates and place them elsewhere. Basic ability.
Unread 09-04-2012, 00:02
JohnFogarty's Avatar
AKA: @doctorfogarty
I used an interface to store encoder values that I then used in a similar fashion.
John Fogarty
