Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 22-03-2012, 20:30
Re: Driver Station not picking up Kinect
If you aren't using it, make sure the I/O tab is not set to Extended. If it is, click the Configure... button and change it to Compatible.
Greg McKaskle
