team 2175 fighting calculators 2012 robot
Better late then never but here's team 2175s unveil video
http://www.youtube.com/watch?v=jG9Di730AZk specs Drive train 10 4in plaction wheels driving wide Using Custom shifting gearboxes powered by two CIMs each Shooter fixed angle shooter 4 8in plaction wheels powered by custom four motor gearbox gearbox uses two fisher price 0673 (5:1 ratio) and two 550's (~4.615:1) Any questions feel free to ask Last edited by Boe : 20-03-2012 at 22:27. |
Re: team 2175 fighting calculators 2012 robot
Why did you guys decide to go with the 4 in wheels...And why 10 of them?
we did 4 inch wheels to keep our CoG low and ten wheels to make barrier crossing easier. even though we designed to cross the bump we prefer the ramp because the bump is a little rough on the robot, and so far we haven't experienced any bottlenecks at the ramps. So we'll probably not be crossing the bump except as a last resort.
Our drive base is similar to yours. FRC 2046 went with 10 4-in wheels also, using WCD type cantilevered axles. The smaller wheel lets us use smaller gearing in the transmissions, but more importantly gives a longer wheelbase for stability in traversing the barrier and with balancing. We raise the 4 outermost wheels approximately 1/8 inch to further improve our turning. Our "multi-tool" appendage is designed to help us traverse the barrier. We pretty much ignore the bridges except for balancing. |
Good looking robot but I have to ask why the need for 4 motors on the shooter?
having the 3rd and 4th motors reduces the amount of time required for the wheels to spin back up to speed. It also allows us to fire a key shot at 40% power instead of 90% power (just guessing percents here) and plus its just awesome ![]() |
#7
ultimately we lost in quarters due to some great defense by team 93. |
#9
we did use encoders to keep constant speed on our wheels, it was really just figuring out the speed we needed. as far as i know our vision lined us up most of the time. The balls just vary so much from new to slightly used to dead which varied distance by a lot. why cant all the balls be exactly the same that's all i'm asking for FIRST please
