Go to Post One button, ten copyrights, you do the math. - StephLee [more]
Unread 21-03-2012, 15:33
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Ring light not bright enough in camera feed
Originally Posted by RufflesRidge View Post
Bingo! Change the setting for the Exposure to "Hold Current" in Begin.VI to avoid messing up your settings after you have performed the procedure Patrick described (which you could do programatically from LabVIEW, but is much easier with the browser).
Thanks, I set both exposure and white balance to "Hold Current" In the begin.vi. I'll have to wait till friday to actually change camera settings on the camera itself.
Unread 21-03-2012, 16:46
Sorry my explanation wasn't more detailed. The camera has flash storage. If you don't want the program to control something in Begin, just delete it and the camera settings will be used. You can use the browser or vision assistant to view and change settings.
Greg McKaskle
Unread 21-03-2012, 17:37
pfreivald's Avatar
AKA: Patrick Freivald
I believe we opened the camera settings in a browser window and did it there.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 21-03-2012, 17:55
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
There is a Camera Performance Example that can be used to set and hold the white balance.
Just add a "Set WB" .vi after the while loop and before the CLOSE.vi, and configure it to "Hold current". Make sure you hold a plain white object (piece of paper works well) in front of the camera for ~15 seconds while running the vi. Make sure the object fills the video frame and reflects the light from the environment into the camera. Then make sure you exit by pressing the "Stop" button on the front panel. This will "Hold" the current white balance in the Flash Ram in the camera.
Then just set the White Balance in the Begin.vi to "Hold current". This will cause the camera to use the calibrated white balance value from then on, or until you change it at the next competition you attend.
Unread 21-03-2012, 18:32
I'm curious what people's images look like with the very bright LEDs and messing with exposure times.
We used 6 blue LEDs, and did not change any camera settings, and got good results.
Unread 22-03-2012, 01:33
grimmcoder's Avatar
grimmcoder grimmcoder is offline
grimmcoder
AKA: Justin Grimm
FRC #2046 (Bear Metal)
grimmcoder is an unknown quantity at this point
We actually held a white piece of paper about 4 inches away from the camera to blind itself, then set it to auto.
Unread 23-03-2012, 15:56
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Using purple LEDs with good results. We just thought that would be the most uncommon color in the enviroment and picked that.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 23-03-2012, 21:44
pfreivald's Avatar
Interesting... Are they from Superbrightleds.com, because we couldn't get a good image at any real distance with the purple ring lights from there.
Team 1551
I write books, too!
Unread 23-03-2012, 23:16
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
4 green LED rings work perfectly for us.
Unread 23-03-2012, 23:36
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Out of curiosity, how many of the teams who commented on this post are using the Axis 206 vs. the Axis M1011. We tried both and noticed that it is much easier to change the settings on the M1011 (but unfortunately our 1011 won't connect to the Driver Station wirelessly).
We noticed that the M1011 had a direct control over exposure via a sliding bar going from 0-100 (doesn't require the light fiddling) and it also had a contrast setting. Both of these were absent from the earlier 206 model.
www.sharkattack744.com
Unread 24-03-2012, 07:50
Which DB? The SmartDB requires that you enable anonymous access.
Greg McKaskle
Unread 24-03-2012, 17:29
Greg McKaskle
If you were asking me, both dashboards did not work, and we had enabled anonymous access.
Unread 24-03-2012, 19:47
Can you describe the setup, and did the camera work at any other point in the season? Can you ping the camera from the DS laptop?
Greg McKaskle
Unread 24-03-2012, 22:34
dellagd's Avatar
AKA: Griffin D
No, they are strips from pepboys! They are so bright, they are difficult to look at and easily saturate the targets if the camera is not set correctly
We play tomarrow at Lenape in New Jersey. Look up what matches 2607 is in any you might see us use them. Woo! 6th place so far!
go to theredalliance.com
