Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 23-03-2012, 14:21
Andrew Lawrence
Posts: n/a
pic: 256 painted chassis
Unread 23-03-2012, 14:24
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: 256 painted chassis
Originally Posted by SuperNerd256 View Post
Note to self: Next time get a paint that washes off of skin.
Paint thinner or any Orange Pumice hand cleaner would help.
The base looks nice!
GitHub
Unread 23-03-2012, 14:27
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Looks great!
[SPOILER][/spoiler]
Unread 23-03-2012, 18:28
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Is there a reason you guys decided to go with the black tubing intake over a standard roller? You might have a little difficulty picking up balls that are against the wall.
Unread 23-03-2012, 19:17
Andrew Lawrence
Posts: n/a
We wanted to pick up from both sides, and decided it would be simpler to have one central pick up area in the middle of our robot instead of two separate intakes on either side converging into one tower, causing more balls to get stuck.
Thanks all for the kind words and advice! I'm looking into getting that orange hand pumice cleaner now.
Unread 23-03-2012, 19:41
Is this your practice bot or are you assembling 30 pounds at your competition? Just wondering how you managed to do this within bagging and robot allowance rules since I'd love to have our frame powdercoated between a competition.
Unread 23-03-2012, 19:47
Andrew Lawrence
Posts: n/a
This is our "practice" bot, but it will be used in competition. We will switch out the top and bottom frames (both weighing less than 30 pounds each) separately at our two competitions, so by the time we get to Central Valley, we'll have the whole "practice" bot competing. Until then, we'll have to settle for a colorful top-half of the robot at SVR.
It's not powdercoated. We hand-painted it in a little under 1/2 an hour. We also welded it entirely ourselves (mentor welded, but we designed), and that took a little less than a few hours. We guestimated that by doing it this way, it would save a bunch of time rather than getting it custom cut and powder coated. If you don't have the time or resources to get your robot custom done, or powdercoated, I highly suggest doing this. Not only is it simple, it's cheap, takes no time at all, and looks great!
Unread 24-03-2012, 03:33
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Any idea of the weight before/after?
Unread 24-03-2012, 03:55
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
I understand that it is cheap and takes no time at all but I would suggest that a few of your buddies and yourself search out for a local powder coat sponsor who can turn around in a day or so. That day, you guys can work more on making your bot better than waiting for paint to dry.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 24-03-2012, 04:08
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Why not spray paint, though? It goes on much faster and more evenly.
Spray paint tends to have a rather inviscid composition that lends itself to nice smooth finishes (except around sharp edges). Brushes and normal paint often leave brushstrokes (unless you thin the paint correctly).
Unread 24-03-2012, 04:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'd go with Cory, much better overall finish.
Stays on way better than regular paint, plus while our parts are out to powder. We have time to work on other items.
Like Cory said, we have about 2-3 powdercoat sponsors that do about a 4 hour turnaround for us. Only takes about 2-3 hours to really powdercoat a part.
-RC
R.C.
MadTown Robotics Team 1323
Unread 24-03-2012, 04:14
-RC
Sorry to the jack the thread for a sec, RC do your PC sponsors do the prep work for your parts too? (like fine sanding and cleaning)
Unread 24-03-2012, 04:42
Yeah—sorry, I meant spray paint was better than a brush. Powdercoating is definitely better than mere paint of any variety; it's just a little harder to arrange logistically.
Unread 24-03-2012, 04:48
R.C.'s Avatar
Akash we have three sponsors that gladly donate their time.
The first guy doesn't care, the PC place is apart of the company I work for. He basically will shoot anything we give him and we'll receive it back within 4 hours. So we have to do all the prep work, mainly just clean and debur parts. Which we have learned to do anyways.
The 2nd/3rd place really cares about detail, we do zero prep work and we receive the parts back in 1wk. They'll clean/sandblast parts along with do multiple coats... Which is a good and bad thing. We only give them parts when we don't care about timing and the our go to guy is backed up.
I'd honestly speak with your powdercoating place, the best thing to do is to just have it prepped ready to go. It makes their life easy and they'll be much happier. Plus they'll turn around the part hella fast.
-RC
R.C.
Unread 24-03-2012, 10:54
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
1 day turn around? Our sponsor can sometimes do it in 1 day, but they generally tell us it will take about 2-3, especially depending on what kind of jobs they have. 1 day is excellent if you can find it.
We spraypainted a few of our parts, and they look horrible in comparison to our powdercoated frame and other pieces. The pain comes off extremely easily, isn't as bright and shiny, and it doesn't even hide the finish. It's hard to find a better process than powdercoating.
Does anyone have experience with car paints or anything similar on an FRC robot?
