Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 24-03-2012, 00:25
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: pic: 2949 PWNAGE: 2012 Robot
Really great robot! Thanks for helping us at GKC in quarterfinals!
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 24-03-2012, 01:38
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
We went with the belt shooter for a couple of reasons. First, because the belts have a shooting length of 14in, it gives the ball more contact time to be able to build up to the full speed that the belts are running at. We found that with the wheel shooters, you tend to have less contact time with the wheel, which means you had to compress the ball more to be able to shoot it far enough. After doing some prototyping, we found that compressing the ball too much made the ball deform a lot in mid-air, and we wanted to avoid this. So because the ball can get to the full velocity of the RPM of the belts, we don't have to compress the ball nearly as much. Also, we are able to more precisely change the amount of backspin we put on the ball. Each side has an encoder on it, so we can adjust the distance the balls travel using a PID controller.
With everything in FIRST though, there are many different effective ways to score the balls in this years game. Personally for us this was the best and most accurate way that we found.
Hope that explained it well.
Thanks for partnering with us! Our alliance ran into some bad luck there but I know we learned a lot from KC and I'm sure you guys got a lot out of it too. You guys have a great robot!
-Nick
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
