Go to Post The great thing about FIRST is that there actually are 3,000 ways to win. Find yours, and leverage it. - Siri [more]
View Poll Results: Which do you use
polycord 49 84.48%
urethane belt 9 15.52%
Voters: 58. You may not vote on this poll
Unread 23-03-2012, 10:03
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Which does your team use polycord or eurathane belts?
I was just curious what teams were using for there elevator/ lifter and what your reasoning was behind it.
EDIT: i mean for the first poll selection round belt, the second one flat belt
Unread 23-03-2012, 10:18
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Which does your team use polycord or eurathane belts?
Polycord is a brand name of urethane belts.
--Madison--
...down at the Ozdust!
Unread 23-03-2012, 10:19
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Correct me if I'm wrong but I thought Polycord was a brand name of a Swiss made urethane cord. In other words, Polycord is urethane.
other examples:
Most people incorrectly refer to polystyrene foam cups as Styrofoam. Incorrect !!
Polystyrene come in two forms. Extruded and Expanded. Expanded is what the drinking cups are. Extruded is the building insulation. Expanded cells will collapse and hold water, Extruded will not. That is why it is illegal to build boat docs from expanded.
Styrofoam is extruded polystyrene made by Dow Chemical. It is blue. Not pink, not white, and and not cups.
Coca-Cola is cola carbonated sugar water caramelized soft drink.
Pepsi isn't Coke, Sams Cola isn't Coke. But they are all cola's..
Ed Barker
Unread 23-03-2012, 10:24
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I demand a 3rd option: Polyurethane Round Belt
Unread 23-03-2012, 10:28
Nate Laverdure's Avatar
FRC #2363
Ooh, this is fun! I've got some:
Does your team use Kleenex or facial tissue?
Does your team use Allen wrenches or hex keys?
Does your team use TiVo or a digital video recorder?
Unread 23-03-2012, 10:30
I'm back
AKA: Matthew Lantry
you know what i sorry I'm so use to using a brand name over its generic name but if you look at the post i did make an edit.
Unread 23-03-2012, 10:31
How about a Xerox or a copier? (Think carefully...)
Mac/PC is a moot point. Macs are PCs (Personal Computers).
Unread 23-03-2012, 10:40
ebarker's Avatar
AKA: Ed Barker
I use Kleenex. The team uses Allen wrenches. I TiVo the game when I'm at robotics.
We keep our drinks cool in the Frigidaire. And our drinks are always ko-cola.
We move piles of dirt around with our Bobcat ( skid-steer )
Hey, pass me a Q-tip.
To answer your question, round belts, solid core. We heat weld them together.
We took an aluminum plate that we heat with a hot air gun on one side and we press the two ends together on the other side of the plate. The students are skilled in watching the face of the cord applied to the plate heat up and deciding when to then put the ends together for the weld.
Ed Barker
Unread 23-03-2012, 14:46
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
Don't forget about your Formica countertops and Linoleum (or Pergo) floors!
To answer the question, we used 1/4" round, solid core, polyurethane belting that we welded (melted) together - orange so it matches our color scheme. Works very well.
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 23-03-2012, 17:40
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Saying this in an Apple store will get you a dirty look from the 'genius' assisting you.
We used round polycord. Lighter and easier to work with.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 23-03-2012, 18:37
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
We didn't have either, so we used Gates belts with minibot wheels on pickup. It works very well.
Unread 24-03-2012, 15:16
DonRotolo's Avatar
Back to humble
FRC #0832
I know you know what my team uses , but you may not know that the choice of belting entirely depends upon the application. Some belts are better than others for some things.
Unread 25-03-2012, 19:45
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
To answer your question, we used probably 60 ft of urethane belting from McMaster Carr and used a heat gun to mesh them together. After that we used a belt sander(disk type) to remove the lip where they were joined which really helps them to last longer on the robot. We use them to transmit power as well as pick up balls and have had no failures recorded with them.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 25-03-2012, 20:28
pfreivald's Avatar
AKA: Patrick Freivald
We used .25" surgical tubing for our belts. To connect the ends we used about two inches of very small round urethane belting (solid) that barely fit inside the tubing (you had to roll it on to get it to stay). That and some superglue = we "broke" two very cheap belts over the course of two regionals, and can fix them in a matter of (literally) seconds.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 25-03-2012, 21:22
Billfred's Avatar
Billfred Billfred is offline
I'll avoid beating the dead horse (glue is too cheap), and say this:
We used 3/16" solid-core round belts, clear (because orange would be mild heresy thanks to our USC sponsorship), welded with a lighter in a jig made from scraps. We've had some jump their pulleys (not unexpected due to the nature of our robot), but none have broken.
