Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 24-03-2012, 14:51
BrandonAbe BrandonAbe is offline
FRC #1025
BrandonAbe is an unknown quantity at this point
Axis 206 help needed!
Hey. I am having some vision problems. When I set up the Axis using the imaging tool to use my bridge it works fine. However, once I turn off the robot and turn it back on again, the camera won't work in my driver station. I have my station set to 10.10.25.5, and the camera is still at the default IP 192.168.0.90. How can I get my driver station to load the image every time the robot turns on? Below is a sample of my robot's camera code...
// Acquire the camera object
printf("Waiting for camera to boot\n");
Wait(5.0);
printf("Getting camera instance\n");
AxisCamera &camera = AxisCamera::GetInstance("10.10.25.15");
printf("Setting camera parameters\n");
camera.WriteResolution(AxisCamera::kResolution_320 x240);
camera.WriteCompression(20);
camera.WriteBrightness(0);
// Process the camera image
if ((m_teleopPeriodicLoops % 10) == 0) { // 5 Hz
AxisCamera& camera = AxisCamera::GetInstance();
if (camera.IsFreshImage()) {
ColorImage *image;
camera.GetImage(image);
BinaryImage *thresholdImage = image->ThresholdRGB(threshold); // get just the red target pixels
BinaryImage *bigObjectsImage = thresholdImage->RemoveSmallObjects(false, 2); // remove small objects (noise)
BinaryImage *convexHullImage = bigObjectsImage->ConvexHull(false); // fill in partial and full rectangles
BinaryImage *filteredImage = convexHullImage->ParticleFilter(criteria, 2); // find the rectangles
vector<ParticleAnalysisReport> *reports = filteredImage->GetOrderedParticleAnalysisReports(); // get the results
for (unsigned i = 0; i < reports->size(); i++) {
ParticleAnalysisReport *r = &(reports->at(i));
printf("particle: %d center_mass_x: %d\n", i, r->center_mass_x);
printf("\n");
// be sure to delete images after using them
delete reports;
delete filteredImage;
delete convexHullImage;
delete bigObjectsImage;
delete thresholdImage;
delete image;
Unread 24-03-2012, 15:01
Re: Axis 206 help needed!
Try picking up the latest Axis Camera Tool from NI Utilities Update. The original kickoff one had a settings bug that lost the camera when it was powered down.
Fixes in 2.0
  • cRIO Imaging Tool - Timeout error due to various network interface configurations
  • Setup Axis Camera Tool - Axis 206 camera loses communication after power cycle
The camera is also normally set to 10.10.25.11 (rather than .15)
Unread 24-03-2012, 17:02
FRC #1025
Thanks, I'll try it out when we unbag again on Tuesday. I was trying arbitrary numbers, and I saw someone used .15, so I tried it. Thanks for all the help.
