Go to Post ...there is just something that I like about the smell of fresh engine oil... - Matt Attallah [more]
  #31   Spotlight this post!
Unread 17-03-2012, 08:25
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: FRC Team 973 2012 Robot :: Encore
Originally Posted by GarrettF2395 View Post
I've found it very interesting that a lot of teams with higher-end machining capabilities have made their turret rotation at the base of the robots "tower", instead of directly under the shooter itself. Are there specific advantages to this?
Going off what Cory said, we've found that, depending on how far out rotated our turret shooter is, balls don't enter quite as easily. They still get in, but it may take a few tries from our storage-to-shooter system to get it. By having a rotating elevator turret, balls will almost always get into the storage system.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
  #32   Spotlight this post!
Unread 17-03-2012, 08:49
FRC #1836 (MilkenKnights)
Because you have 4 wheel independent swerve, I was wondering the breakdown of the motors you use and what they are for.
  #33   Spotlight this post!
Unread 17-03-2012, 21:38
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Their swerve is very sophisticated, but the rotation is done with window motors and each wheel has its own CIM.
  #34   Spotlight this post!
Unread 18-03-2012, 00:47
First of all, we had a great time competing with 973 and 294 at LA. We couldn't have asked for better alliance partners, and we are so grateful for all the work you did to make our robot more consistent for elims.
I understand, but we are not allowed 4 window motors, which would be required for independent swerve with windows for rotation. Also, I was wondering what motors/ how many they used for the shooter/elevator/ground pickup/swerve modules.
  #35   Spotlight this post!
Unread 18-03-2012, 01:01
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
You are allowed 4. Rule [R48] part C specifies you may use 2 window motors of either of the listed model numbers, and part I specifies you may use 2 window/seat/door motors from ARA or a previous year's kit of parts. This means you can use up to 4 window motors.
  #36   Spotlight this post!
Unread 18-03-2012, 01:20
Sorry, forgot about that.
  #37   Spotlight this post!
Unread 24-03-2012, 18:23
bam-bam bam-bam is offline
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
Could you post a picture of the Emperor Swerve? I'm intrigued. I'll obviously ask more at the Champs.
Great robot, and love the rotation on the tower itself.
  #38   Spotlight this post!
Unread 24-03-2012, 18:30
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
They they CAD posted on CD.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #39   Spotlight this post!
Unread 24-03-2012, 19:22
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
I can do one better! 973 has posted their CAD on FRC Designs! Check it out!
http://frc-designs.com/html/CAD_Offseason.html
Matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
  #40   Spotlight this post!
Unread 24-03-2012, 19:29
Matt
Thanks!
  #41   Spotlight this post!
Unread 24-03-2012, 19:45
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
I'm mostly curious, but what are the limits of rotation on your turret? It would be really cool to have fully independent swerve with a fully independent turret with a fully automatic video tracking system.....
-Alex
2010 Washington DC Regional: Engineering Excellence Award
  #42   Spotlight this post!
Unread 24-03-2012, 20:17
Aren Siekmeier's Avatar
on walkabout
Originally Posted by Cory View Post
Balls always enter the shooter from the exact same orientation.
This is the biggest one, but you also get the weight from the turreting mechanism that much lower.
  #43   Spotlight this post!
Unread 22-04-2012, 13:01
Joe195's Avatar
Joe195 Joe195 is offline
Mechanical Designer
FRC #0195 (Cyber Knights)
Team Role: CAD
Joe195 has a spectacular aura aboutJoe195 has a spectacular aura aboutJoe195 has a spectacular aura about
Talking Re: FRC Team 973 2012 Robot :: Encore
Great Robot guys! I really loved how you combined many great things into one package, like swerve, accurate turret shooter, intake, etc. Great Job. It would be amazing to team up with you at champs! Good luck!
  #44   Spotlight this post!
Unread 25-04-2012, 12:25
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
It's a bit heartbreaking to be sitting in California while the entire team is heading out to St. Louis this week to compete for a title yet again. However, college held me back and it is a priority.
With that said, I just wanted to wish the best of luck to the team this weekend. I know I will be watching as much as I can. Being an underdog in a stacked division could be difficult or a blessing in disguise.
This team has so much to be proud of and I can say from being with them the entire season, they have worked so hard and so much for this one week. With the upsets that came to us in Los Angeles and Central Valley, it is only fitting that winning here would suffice for all that hard work.
Regardless of the outcome, these students along side with my co-mentors should all be extremely proud and happy of their accomplishments.
Good luck this weekend guys! I'll try and be there every step of the way. (almost!)
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
