Thread Tools |
Rating:
Display Modes |
Re: Highest score so far?
Twitter data weeks 1 through 4. Be aware: Twitter data has many omissions and some errors. Last edited by Ether : 26-03-2012 at 10:11. |
Highest score in Seattle Olympic was match three of the finals: 68-67, with no fouls.
Well 67, 548 and 3656 in Elim. 1 scored 100/39 against 543, 1322 and 3668.
Finals Match #1 in Waterloo was 105-16
Winning alliance was 1114, 2056, and 4372, against 244, 1503, and 2852. 105 is the highest score this season and this is probably the biggest difference in scores also with a difference of 89. |
Actually 113 is the highest score.
Also the 113-9 was the largest margin of victory at 104.
#7
I really think we should be looking at unpenalized scores (HS+TS+BS) when we try to figure out what the highest scores in the World are.
113 doesn't look so incredible when there are 27 penalty points. |
#8
I thought about that too but those points are part of the game. If a player in the NBA drops 50 on another team, everyone isnt going to dismiss it if he went to the free throw line 20 times. The penalty points are part of the game and you can win a match because of those points too, so I would count those towards the high score.
#9
Thus far the highest HP+TP+BP score I can find is Waterloo E-13 where 1114-2056-4372 put up 100 points before fouls (103 after).
#10
Similar to Ether's post above (also based on his twitter data), with team numbers included.
Top 5 Total Scores Code:
Event QE M# Bot1 Bot2 Bot3 total WCA E 20 548 67 3656 113 WAT E 19 1114 2056 4372 105 WAT E 13 1114 4372 2056 103 MA E 5 246 233 341 103 OC1 E 1 469 67 2851 103 Top 5 Unpenalized Scores Code:
Event QE M# Bot1 Bot2 Bot3 UP Score WAT E 13 1114 4372 2056 100 WI E 19 269 48 2826 98 WAT E 19 1114 2056 4372 96 WAT E 5 4372 2056 1114 96 WI E 20 2826 48 269 95 Code:
Event QE M# Bot1 Bot2 Bot3 hyb NJ Q 82 869 1676 224 46 MA E 13 246 341 233 42 MA E 20 341 233 246 42 WAT E 19 1114 2056 4372 41 Code:
Event QE M# Bot1 Bot2 Bot3 tele WI E 19 269 48 2826 54 MA E 1 233 341 246 54 WI E 20 2826 48 269 51 WAT E 13 1114 4372 2056 50 Code:
Team Triples 67 10 469 9 548 5 3656 5 2851 5 1635 5 522 5 125 5 |
#11
548 actually has 6 triple balances 5 from the Northville District and 1 from Greater Toranto East Regional.
#12
All I can say is, just wait for next week, at GTRW (ON2), when the likely top seeded alliance of 1114/2056 has a lot bigger pool of talent to choose from for the 24th pick.
Its been interesting at the 2 Ontario regionals thus far. Both times, its come down to the last round of matches to decide if 1114 would be the #1 seed, with 3161, 1815, and 610 all within closing distance at round 11 of the matches. Good luck for 1114 kept them in the #1 seed, with successful coopertition in their last Qualification match at GTRE from 2852, and a well timed unlucky match for 3161 in the last round at WAT. Someone else seeding #1 would certainly make for a more even distribution of the firepower. A matchup of 1114/907 vs 188/2056 would certainly be more even than 1114/2056 vs 907/188. Would it make for better matches? I'm not sure; there is definitely something to watching the expert level at which an 1114/2056 alliance plays the game each year. To me, the Montreal regional put up the most interesting show. The high volume of rookies, and the lack of any significant veteran powerhouses (the closest thing was 176 and 2590), lead to an impressively even matching in the eliminations. A quarter-final, both semi-finals (alliances 1,2,3, and 5), and the finals (alliances 1,3) all went to 3 rounds, with admittedly low, but at least close scores. |
#13
Highest total match score, foul points included: 191, ON2 E19 Highest alliance score, foul points deducted: 102, ON2 E19 Highest total match score, foul points deducted: 185, ON2 E19 |
