Go to Post If you look at where you have come from you can often tell where you are going. - Turtlecoach [more]
  #61   Spotlight this post!
Unread 20-03-2012, 00:30
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Stopping a Triple Balance
UNLESS your mecanum-drive robot has (1) "super-creep" (low geared, high torque - I think that's what they call it, I'm not a mechanical type) mode where it just crawls right up there, alone OR pushing another bot, and (2) "e-brake" gyro-based software which enables it to hold its position on the bridge using micro-adjustments (that's in lay terms and I might not be getting it right, but it's the general idea).
I dont believe torque is the problem with mecanum wheels. The problem is that mecanum wheels just arnt designed to go up a ramp. I believe that when going up, the rollers on mecanum wheels (those that are the whole reason the function to strafe) just act like casters and you slide down the bridge. This is what we saw in very early testing anyway. In a way, this can be looked at as having "very low traction" on the bridge.
Anyone else see the same thing?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #62   Spotlight this post!
Unread 20-03-2012, 21:45
Squillo Squillo is offline
AKA: Cynthia Hannah-White
FRC #2465 (Kauaibots)
Squillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant future
Well, all I know is that our (mecanum) wheels have absolutely no trouble going up the bridge (which is built as best as we could to spec, with the proper surface covering). Or stopping on the bridge while it is fully tilted. I guess I will leave it to the techies (I'm just the rulesmeister) to explain why (except I don't think any of them are on here).
And of course I'll eat my words if it doesn't work that way on the competition bridge. I love words, they're so tasty, I eat them all the time. (now what smiley would you put here? wink? embarrassed? ???)
  #63   Spotlight this post!
Unread 21-03-2012, 07:05
pfreivald's Avatar
AKA: Patrick Freivald
We can drive up the bridge and balance with just our mecanum wheels, too -- though balancing is even easier and more consistent with the traction wheels down. Where the traction wheels shine over the mecanum wheels is not moving nearly as much when bumped by a clumsy or over-exhuberant balancing partner.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #64   Spotlight this post!
Unread 25-03-2012, 12:52
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Originally Posted by Zoughtbaj View Post
Likewise. At the Oregon Regional, just about every Mecanum I saw not only could not easily balance on the bridge, but had trouble even getting over the bridge. Interestingly, it would seem that CG would have a lot to do with that, but after what I saw, all the tipping and violence in the balancing process would simply cause the Mecanum wheels to slip. Traction wheels are definitely nescessary for a tripple balance.
We have mecanums and were very good at balancing in the Boston regional -- the robot never slid, nor did it take us more than 10 seconds to double balance. We also did a triple balance with 246 and 3958 on the practice field without traction problems.
EDIT:
Originally Posted by pfreivald View Post
I think part of the issue is that some teams have their mecanums geared way, way too high for easy bridge-climbing or balancing... Though from what I've seen this isn't just a mecanum problem.
We're using 1:16 worm drive and gearing was a non-issue.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #65   Spotlight this post!
Unread 25-03-2012, 12:54
pfreivald's Avatar
Team 1551
I write books, too!
  #66   Spotlight this post!
Unread 25-03-2012, 20:54
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I have to agree. I've had many a team tell me simply, "we can't climb the bridge; see, we have mecanums". They don't seem to realize that this is largely meaningless without specifying gearing, but I'd believe some of their ignorance may be spreading to some other teams.
  #67   Spotlight this post!
Unread 25-03-2012, 21:08
Djur's Avatar
WPILib
AKA: Sam Carlberg
Again, mecanums are not unable to climb the bridges as demonstrated here and here (with lower weight and gearing). I'm not sure why people think that mecanums can't do this.
  #68   Spotlight this post!
Unread 25-03-2012, 22:33
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Because they weren't here for the 45 degrees carpet in 2010?
  #69   Spotlight this post!
Unread 25-03-2012, 22:41
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Just throwing this out there that 3572 did an excellent job playing defense and stopping 2054 from balancing in the semifinals of Niles FiM tournament. Great job guys! Thanks to 2834 as well for your shooting. Might want to get the topic back on to stopping triple balancing though.
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
  #70   Spotlight this post!
Unread 26-03-2012, 04:12
Well, we did actually have a LITTLE more trouble on the competition bridge, but it wasn't due to the mecanums. It was because our CG was too high. Midway through the competition we adjusted our weight distribution, and after that, we not only climbed the bridge, but balanced it successfully (alone and with a partner) several times.
The only sad thing was that we had a great strategy for achieving a triple balance with another very narrow bot (we tested it on the practice field, the two of us could actually climb the bridge side by side!) and any third bot, but neither of us were captains, and we got picked by the 6th alliance, and then the 7th picked them, splitting us up. So we never got to do it - and there was no triple balance at the Hawaii regional .
But overall it was a fantastic competition (the field system problems aside, that's another issue and we know they're working on it), our first elimination victory (we went down 2-1, but at least we won one! Last time we made it to quarters we lost 2-0), and it was great to see our bot dunking balls consistently in hybrid, picking them up, scoring, and balancing. Really rewarding to see all that hard work pay off.
So for us, next year starts tomorrow.
  #71   Spotlight this post!
Unread 26-03-2012, 04:27
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
In the elimination round at Denver we successfully defended against a triple balance team, in the second match we were unsuccessful because they prevented us from crossing the field until the end of the match. I think that an alliance geared towards a triple balance should take a hard look at playing anti defense until 2 robots are on the bridge by preventing defenders from crossing the field or interfereing. Once we figured out that they would block the cooperation bridge and switched to our alliance bridge for crossing, they were unable to complete the triple balance.
