Go to Post Every now and then, the judicious application of a modicum of common sense can make all the difference in the world. - dlavery [more]
Unread 25-03-2012, 01:45
FRC #1836 (MilkenKnights)
Wiring through Frame
One thing that our team saw thought of doing for next year, was running wires through frame pieces. It seems a lot cleaner and more professional than having wires taped all over our frame. I know for a fact 254 does this. Does anyone have any recommendations, tips, or particular tools and materials that we would need to execute this for next year?
Unread 25-03-2012, 01:57
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: Wiring through Frame
1515 uses Wire Loom. It's fairly effective, and provides insulation that would be necessary when running through the frame. Wire bushings are useful for insulation and aesthetic purposes for the exit point of the wire through the frame.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 25-03-2012, 02:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Think about where you put your connections. You don't want to have to place a connector in an inaccessible spot—otherwise you'll have to pull the wire out to get at it.
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
Use labeling and color to make tracing easier both for troubleshooting and inspection. Based on the robots I've seen so far, I'd make that recommendation no matter how you choose to organize your wiring. It's especially important if the wiring will be hidden.
Also, permanent attachment at either end isn't recommended if you need to swap out components or remove major sub assemblies for repair or transport. Another consideration if the wiring is "trapped" inside the frame.
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
Unread 25-03-2012, 02:15
NagyH NagyH is offline
NagyH has a spectacular aura aboutNagyH has a spectacular aura about
I would recommend trying to keep it as clean as possible. If you're routing wires through tubing and you get a jumble of wire or something stuck in there, it's a pain to get out. I would also suggest covering up the edge of the holes through which your wires enter and leave. For example, we put rubber rubber "linings" that cover the edge of the hole in the tube. So when we pull the wires out or push the wires in, they don't get damaged. If you look at the top part of our elevator in this picture, you can see the wires running out, and the hole covered by the rubber plug.
Running wires and pneumatic tubing through our frame helps us give a clean look to the robot. In addition, it also ensures that they won't get damaged, cut, or caught by other parts of the robot.
Unread 25-03-2012, 04:55
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
If you do do this, make sure that your robot is mechanically not going to have any major changes.
Last year our team routed cabling through our arm, it all worked wonderfully until we had to change out our arm at comp. We weren't able to pull them out quickly enough so we had to cut, trace, and re terminate each cable.
Now we make sure that there is a connecter at any point that is likely to become detached. This year we also ran most of our cables along beams, and cable tied them down every 1-2". If you have the patience to line up all the wires and do it properly, you can end up with a very professional look. Having cables exposed along the whole run makes tracing them and trouble shooting much easier as well.
It comes down to how well you think you can pull it off, as a younger less robot focused team, we prefer to have cabling on the outside because it provides more flexibility. If your team can pull it off both mechanically and electrically, then go for it!
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 25-03-2012, 09:14
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Also keep in mind that any hidden wires (like those going through the frame) are a magnet for drill bits! Once you route wires through the frame, the team needs to start checking in the frame every time they want to drill a hole for anything to make sure they won't hit a wire. For that reason, we make sure all o our wires are visible. They're all routed neatly and in bundles that are attached to the frame, but the don't go in it.
Unread 25-03-2012, 09:48
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
We have actually been going in the opposite direction lately. Our team has used Panduit wire ways in the past. They look clean and are much easier to use when making changes than running wire through tubing. But even with an easily removable cap changes were often just too time consuming and difficult. This year we only used cable ties to attach wires to the outside of the frame and wiring was much easier, faster, and ended up being more reliable than previous years.
I have also encountered problems with wires routed inside tooling frames at work. The insides of tubes must be fully cleaned and deburred, you need to limit the fill percentage, and avoid sharp turns or too many turns. Also, the issue of drilling into wires is a real and present danger any time you make a change. You think you will remember that the wires are in there and where they go, but it is so easy to forget. Out of sight, out of mind.
This is the zeroth day of the rest of your life.
Unread 25-03-2012, 10:02
pfreivald's Avatar
AKA: Patrick Freivald
Yup! We've routed partially through the frame in the past, but have moved even further from doing so for all of the reasons listed here, but most especially this: when you make changes, sometimes what was accessible is no longer accessible, and problems become very difficult to diagnose and fix.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 25-03-2012, 10:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I would spend the time making the robot easily serviceable. And you might find that the more effort you put into doing so, the less service it will need, and the better it will look and function.
Unread 25-03-2012, 10:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We ran tons of wire through the 1x2 box tubing up our superstructure. It worked quite well. I would recommend a TCT hole cutter and some grommets.
Unread 25-03-2012, 11:20
We occasionally will run wiring inside the frame but will do it only when really needed. As pointed out above, mechanical team has a nasty habit of drilling through frame members where wires are contained. Funny story, it is actually how I got dragged into the pits in 1997. Been there ever since.
Unread 25-03-2012, 14:43
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
I would not recommend running wires through tubes, our electronics layout this year was the cleanest it has ever been. Our frame this year was constructed of perforated tubes, so it was a simple matter to zip tie the wires to the tubes every 2-3 inches. In some places we routed wires through the tubes, but only because of how open and pocketed they were.
This is a picture of our robot with the old bridge lowering device, most of the motors were close to our dual electronics boards, but those that weren't were simple to wire because of the ability to zip tie everything through the holes.
http://farm8.staticflickr.com/7188/6...a3d21afd76.jpg
Another dis-advantage to running wire through tubes is that the inside of tubes tend to attract metal shavings.
Unread 25-03-2012, 14:47
Thank you so much everyone. It sounds like people have problems when they change something out. We will probably be doing less of that then other teams, as we are really trying to not change anything once we have CADded it. This year, the only thing we changed was taking off our bridge mechanism. Still, in places that we can forsee taking a mechanism off, we will put removable connectors. Also, we don't usually drill holes in our robot. This year, we took off the bridge mech, because it was so much weight, but the weight problem was mainly an issue of using to thick aluminum tubing.
Unread 25-03-2012, 15:52
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
It looks like you guys used rubber grommets for that application. Great implementation.
