Go to Post the everyone is a winner philosophy cheapens winning. - Andrew Schreiber [more]
Unread 25-03-2012, 13:38
swapnil94 swapnil94 is offline
FRC #2935
swapnil94 is an unknown quantity at this point
US Digital E4P encoders and CIMple gear box
Your kit includes two E4P-360-250-D-H-D-B. These are miniature optical encoders with two-channel quadrature outputs. They are 360 codes per revolution and fit on a 0.25" shaft. See the E4P web page.
That is from http://www.usdigital.com/first
It says maximum shaft size is 1/4". But they are suppose to fit on CIMple gear box. now the output shaft of CIMple gear box, where encodere is attached is 3/8"
http://www.andymark.com/product-p/am-0740.htm
Diameter of small end: 0.374 inch
So how are they suppose to fit?
And if they do fit then they should fit directly on CIM's output shaft since the diameter of that shaft is 5/16" right? And are E4P able to keep up with 1:1 CIM full power?
Thanks
Unread 25-03-2012, 13:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: US Digital E4P encoders and CIMple gear box
Thanks
I'm pretty sure the small end diameter referred to on that AM page is the small bearing seat before the further step down to the encoder shaft. I haven't run across any AM shafts that don't have the proper 1/4" shaft for an encoder, if they have one.
And yes, if properly installed, the E4P is easily capable of keeping up with the output of the CIMple box.
Unread 25-03-2012, 14:51
FRC #2935
Yeah I checked cad file and it is just like you said. Is there any way to attach those encoders on 5/16" shaft? Thanks
Unread 25-03-2012, 15:41
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
No. The E4P is not designed for shafts greater than .250".
There are three options to read the RPM on a 5/16" shaft:
  • link it to an idler wheel with a .250" output, and have the encoder read that
  • turn down the encoder end of the shaft to .250"
  • buy another encoder designed for 5/16" shaft
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 25-03-2012, 15:50
FRC #2935
Thanks!
I think we will turn down the end of the shaft to 0.250". since they have tolerance of 0.020" we just need to turn it down by 1 mm. Filing the ends should do it.
